Old 04-15-2013, 09:05 AM   #1
1adam12
1adam12's Avatar
57 With Camaro front clip?
I just got a 57 with what the PO told me was a camaro front clip..I am not sure how to tell what year i need new tie rods..Ifound a casting number 371876, or 371676 kinda hard to see with a flashlight..Any other way to tell what I have on the front the lug pattern is 5x4.75 with lugs at 7/16 20 lug nuts..Any help would be great.Thanks
1adam12 is offline   Reply With Quote
Old 04-15-2013, 09:35 AM   #2
bhodges061
Re: 57 With Camaro front clip?
I also have a Camaro clip on my 59, and from what I can tell is if the steering box is behind the cross member towards the firewall then it is a first gen and and in front of the cross member it is a second gen. Checkout http://www.camaros.net/ alot of good info on Camaro's and ppl will try their best to help identify the clip. Hope this helps.
bhodges061 is offline   Reply With Quote
Old 04-15-2013, 11:01 AM   #3
Speedbumpauto
Speedbumpauto's Avatar
Correct. 1st gen, rear stear, goes from 67 to about 70 and 2nd gen, front steer goes from 71 to about 79 or 3rd gen.
Speedbumpauto is offline   Reply With Quote
Old 11-04-2013, 03:50 PM   #4
1958Warrior
1958Warrior's Avatar
I don't' know if you ever identified your year clip ,but if it was front steer. 2nd gen clips up to 1978 had smaller diameter outer spindles(3/4"), and 1979 to 1981 had larger outer spindles (.884- 27/32) after 82 the 3rd gens had struts
1958Warrior is offline   Reply With Quote
