06-04-2013, 12:06 PM | #1 |
SBC guys
.....what kind of times are you running? What's to your combo (n/a, nitrous, FI), about how much does your rig weigh, daily driver/weekend warrior/trailer queen, etc.......How are you full size SBC guys competing w/ the BBC guys?!
06-04-2013, 02:43 PM | #2 |
Registered Truck Offender
Re: SBC guys
It's just a matter of cubic dollars.
Street 'legal' but compression dictates c-12 fuel,, At $11.50 a gallon and about 4 miles to the gallon (unless I stick my foot in it) It doesn't see much daily driving. Truck 3550 with steamroller tires, 434 SBC n/a 10.6's @ 118 in street trim, (mufflers and DOT's) in 3500-4000' air No street time at all.. 2680 pound Nova, n/a 434, single carb, 9.1's @ 148 in 1500' air. (800HP cost a litle more to buld than the 660HP, by ohhh about $10k) There is a point where going fast with a small block is purely ego driven. Just proving that you 'can',,, not that it's a smart choice. Same investiment in a pigblock would be in the mid 8's or quicker.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
06-04-2013, 04:55 PM | #3 | |
Re: SBC guys
12-23-2013, 01:57 AM | #4 |
Re: SBC guys
I'm running a 360ci SBC 11.1comp forged bottom, ported sportsman 2 heads, .630/.630 solid roller & 200 shot of juice. Haven't had a chance to run at the track yet. Because first test hit killed tranny. I will post time when I get to the track this spring. Hoping for low 11s.
12-23-2013, 02:50 AM | #5 |
At the body shop.
Re: SBC guys
11.99 so far. 9.5:1 SB 400 hyd roller cam air gap rpm 850 holley.
Drive it 50 miles each way. And had made as many as 25 passes in 8 hours at track rental.
" That didnt make it any newer " " Dont antique the equipment " |
12-24-2013, 12:47 AM | #6 |
Re: SBC guys
My old Gen 3 347ci motor went 11.4x with an OD trans at 3525lbs. You could drive it anywhere any time on 91. With a small 100hp hit from the 60' it went 10.7x.. This was with a converter that was about 1,000 rpm too tight. Probably would have ran 11.2x NA and 10.3x on bottle spraying out of the hole.
Fast forward to the new motor, power glide and back half.. Truck now weighs 3300lbs with me in it, is a 418" Gen 4 motor and has been the numbers in my sig. Again, too tight of a converter, needs to be about 1,200 rpm looser for motor and guessing 600rpm looser for bottle. Haven't been able to make a good bottle pass yet, but hope to go deep 9's before I change the piston and build the twin turbo set up.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
12-29-2013, 12:27 AM | #7 |
Re: SBC guys
What gears and trans does everyone have I have an 86 with a 355 aluminum heads bout 10.5:1 2.02 int. 1.60exh. Only a holley 650 (I know).. Slipping th350 pulling it this weekend to get rebuilt with 3.73s and locker. Went 8.9 at 77 leaving at idle.. Thinking 4.56s bigger carb less weight 100 shot or so.
12-29-2013, 12:57 AM | #8 |
Re: SBC guys
Are you going to run 1/8 or 1/4 or both?
What rpm do you spin it to? What tire do you run? What mph do uou think it will have with the bortle? (100 hit generally equals about 8-10mph in the 1/4)
12-29-2013, 01:09 AM | #9 |
Re: SBC guys
Like to be able to do 1/4 but all that's around here is 1/8th debating 4.11s too
6,000rpm 29x10.5 mt slicks dropped 4" stock 2 leafs with traction bars Not sure about 1/4 mph Removing sway bar help? I've read something about that Had 1.9-2.0 60' leaving at idle and rolling into it. Spun and hopped when I stalled it Tci 3500 stall thinking about dropping it to 2700 when I get trans re done |
12-29-2013, 01:10 AM | #10 |
Re: SBC guys
I'm shifting into 3rd right at finish line with 3.73s and th350 at 80 or so
