Old 01-15-2014, 11:56 PM   #1
brokestudent
Holy poooooo
So I finally got everything out of the door and cleaned out the bottom and this is what I find. Ok, in all fairness I am sure it does not come as a surprise that there's a big hole in the bottom of the door but still. I am curious is it possibleto just cut out the hole/bottom of the pan and weld in a patch (I have plenty of extra metal as I am pulling the metal from the pickup bed that someone installed). Or should I buy something like this http://www.rockauto.com/catalog/more...432&cc=1324280 has anyone used this patch from rockauto? Seems a bit overkill for what I need but that being said I am asking a higher power (the forum). All that being said I found the loud clanking sound coming from the driver door, apparently the old window mechanism fell off and they just left it down there HA
brokestudent is offline   Reply With Quote
Old 01-16-2014, 02:01 AM   #2
Captainfab
60-66 Nut
Re: Holy poooooo
I don't know anything about the quality of the patch panels that Rock Auto sells, but you don't have to use the whole thing. Just cut as much of your rusted area needed to get to good solid metal. Then cut a section of the patch panel to fit the opening and weld in place.
Captainfab is online now   Reply With Quote
Old 01-16-2014, 02:03 AM   #3
brokestudent
Re: Holy poooooo
Yeah but especially since all the rust is just on the flat bottom I think I may just weld some metal in there and not even worry about the patch.
Old 01-16-2014, 02:56 AM   #4
jtrichard
Re: Holy poooooo
if it is just on the bottom and flat and you have good metal left around it just get some sheet the same thickness and go for it
jtrichard is offline   Reply With Quote
Old 01-16-2014, 07:41 AM   #5
PGSigns
PGSigns's Avatar
Re: Holy poooooo
Like Captain fab said you got to cut till you find god metal to weld to. The hole may end up pretty big. Also that patch panel allows you to cut back to the door skin lip and have a piece that will be easier to match to the curves in that corner.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
