Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-21-2014, 11:22 PM   #1
71ChevySS(straight6)
Gas tank out, sub box in?
Howdy y'all! Just curious, has anybody yanked and relocated the fuel tank in their 67-72 and custom-built a sub box to go in its' place? Really want to do this, just wanted to see some pictures if anyone has done it before.
I was thinking something like either three twelves, two fifteen rounds, or two fifteen squares (Kicker Solobarics) across the bottom, with four 5x7s up top and the amp sitting in a cutout on the box (a divit down in the box just deep enough to make the top of the amp even with the face of the box). I really want some bump in my cab, and the door speakers aren't cutting it ;D
Also, where should I run the wiring? I want to keep a rubber floor in it, should it run under the mat along the transmission hump?
71ChevySS(straight6) is offline   Reply With Quote
Old 01-22-2014, 12:10 AM   #2
MadManAndrew
Re: Gas tank out, sub box in?
There is not near enough room for 15's back there, nor do you need them. You don't even need three 12's, two 12's would have much cleaner sound and hit hard enough to rattle your brain in a cab that small.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 01-22-2014, 11:40 AM   #3
big d's red67
big d's red67's Avatar
I have one 10" kicker L7, I have my amp turned way down it hits harder then any 10 I've ever heard. The box is ported on the passenger side and I have a 500 watt amp.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 01-22-2014, 09:55 PM   #4
bwkennedy
I took my tank out cut it out and put three Memphis 10's in it it hit pretty hard
bwkennedy is offline   Reply With Quote
Old 01-22-2014, 11:25 PM   #5
Oh, and what about the head unit? I have a head that's similar to stock (actually, I have a video of it messing up on youtube. Here:). I want to upgrade it, but I don't want to cut the dash up, and I can't give up any space in the glove box. Any thoughts?
Old 01-22-2014, 11:27 PM   #6
Well, it's just that too many of my friends have two twelves, I wanted to raise the bar some
Old 01-22-2014, 11:36 PM   #7
That's similar to what I want to build, except for me one ten isn't going to cut it. :/ I'm in need of bone-rattling, earth-shaking bass lol. I have a 500 watt Bazooka amp, but I'll probably need a bigger one for three twelves, correct?
Old 01-22-2014, 11:38 PM   #8
Hmmm. I hadn't thought about reusing the fuel tank as a box. Nifty idea! What did you do with the filler neck?
Old 01-22-2014, 11:47 PM   #9
Andy4639
Old member
Andy4639's Avatar
I have 2-10" shallow subs in the box behind the seat. They sound fine. The bottom picture is with the old speakers installed. You can check it out in the link.
http://67-72chevytrucks.com/vboard/s...d.php?t=601399
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-22-2014, 11:48 PM   #10
jjzepplin
jjzepplin's Avatar
Me wanna see! Dang Andy... We posted bout the same time. Nice setup!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-23-2014, 12:53 PM   #11
81Scottsdale520
81Scottsdale520's Avatar
i have 1 15 in mine, cheapo box i made, it hits pretty hard though
~When In Doubt Go Lower~
81Scottsdale520 is offline   Reply With Quote
Old 01-28-2014, 02:18 AM   #12
jaysc10
jaysc10's Avatar
here's my setup. i custom made this box with four 6.5's and three 8' subs ran by 4 channel 1000 watt and 2 channel 1000 watt under the seats.[IMG][/IMG]
jaysc10 is offline   Reply With Quote
Old 01-28-2014, 02:19 AM   #13
jaysc10
jaysc10's Avatar
this set up hits harder than my 2 12's in my other car.
Old 01-28-2014, 02:21 AM   #14
jaysc10
jaysc10's Avatar
as for the stereo, i put a deck in the regular spot. only had to a little shaving/cutting, looks good still. don't have a pic of that at the time
Old 01-28-2014, 09:22 AM   #15
Low Elco
I was gonna say, look up ACEX here on the boards. He's got I think 4 8's and it's bangin' something fierce.
Low Elco is offline   Reply With Quote
Old 01-28-2014, 10:20 AM   #16
I like the wood paneling. Nice touch. Do you think a set of twelves could fit across the bottom of the box?
Old 01-28-2014, 10:20 AM   #17
Ill look into him. Thanks.
Old 01-28-2014, 10:22 AM   #18
That's pretty slick. I doubt I would want it to stick out that far in my truck, though. Leg room is already pretty limited.
Old 01-28-2014, 10:17 PM   #19
K10 STEPSIDE
K10 STEPSIDE's Avatar
I built the custom box behind the seats. The biggest thing is having the depth to fit the subs. I am running to 12in Kenwood shallows. There is a big difference in sound from the shallows in my truck to the full kenwoods 12in in my car, but having the sub 6in from your back bone helps with the feel. Also having the subs so close you need a quality sound and seal. My system goes as follows
1-kenwood head unit, 2- spr60's under the dash, 2- spr60c's behind the seat,1-MRX-F65 4-channel amp, 2-Kenwood 12in shallows,1-hyfonics amp. I want to upgrade to a better sub amp and better speakers under the dash, maybe type-x's.
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 01-30-2014, 11:15 AM   #20
calvin78612
calvin78612's Avatar
1 10",2 6x9's in cab corners,and 2 6x5's on kick panel.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 01-30-2014, 02:52 PM   #21
K10 STEPSIDE
Have you thought about going to a center console and bucket seats?
It sounds like you want a lot of sound and I don't know if you can get it to fit without moving the seats forward.
I ran my wiring along the frame and then in to the cab threw the hole that the gas line ran threw.
1967 chevy K10 step
2002 chevy Impala
Old 02-11-2014, 08:56 PM   #22
K10 STEPSIDE
I thought I would take a better picture of my boxes since I had my seats out. Also, I used my boxes to hide the seat belt re-tractors that are mounted to the floor and the area behind the speakers is open leaving space for the re-tractor and belt to pass.
1967 chevy K10 step
2002 chevy Impala
Old 02-11-2014, 09:39 PM   #23
_Ogre
_Ogre's Avatar
while i made this for my 58 it would be easy to adapt to any truck
one sub and battery on this side
two amps on this side
shop air compressor timer
Old 02-14-2014, 09:50 AM   #24
RexDodge
Here's what we built. Sorry I don't have better pics. 12" shallow sub with 6x9's in the corners and some high tech (2) up front in the original spot in the dash. 1200 watt system. Sound is ok...makes me smile anyway.
RexDodge is offline   Reply With Quote
Old 02-17-2014, 05:16 PM   #25
c10seconds
c10seconds's Avatar
Check out these new products from fesler.
1967 C10 SWB 6.8L/4L80
c10seconds is offline   Reply With Quote
67-72 truck, fuel tank, radio, radio wiring, sub box
