04-16-2014, 01:49 AM | #1 |
What flywheel to use?
I am getting ready to put a 2002 6.0L LQ9 into my '68 C10. I was going to use the 4L80e transmission that I purchased with it, but a friend of mine has recently given me a TH 400 that his dad built (Dad builds racing transmissions) and he has no use for.
Question is: Will the flex plate from the 6.0 work bolting up the TH 400 torque converter and do the bell housing and block mounting holes match? I have read a few things about adapters and special bolts, but nothing concise.
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
04-19-2014, 03:34 PM | #2 |
Fabricate till you "puke"
Re: What flywheel to use?
I cant help much...running a stick shift, behind my 5.3? You might shoot Clinebarger a pm....bet he can help, he is the trans 'guru"...Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-19-2014, 04:40 PM | #3 |
Id wether have the 4l80e over the 400 the 4l80 is as bullet proof as the 400 but has over drive no sure on flexpkate
04-19-2014, 04:58 PM | #4 |
Guessing your LQ9 came out of a Denali or Escalade Platform and was hooked to a 4l60/65. So next question is the flexplate on your LQ9 flat or dished?
Also chances are if it came with a 4l80 attached then its more than likely an LQ4 and in that case you the th400 will bolt right up |
04-19-2014, 05:02 PM | #5 |
i recently had the same question about a 700r4, what i was told is that the flexplate will work-but the holes in it need to be elongated by about half a hole. also you need to use a spacer between the flexplate and crank that gm makes and is available through summit racing with bolts.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold 1986 suburban 350/700r/3:73's 31's: parted out. 1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold 1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold 1970 c10 long bed-new project! getting ready for the 6.0 |
04-21-2014, 02:12 AM | #6 | |
04-21-2014, 02:13 AM | #7 | |
