07-27-2014, 06:25 PM | #1 |
erratic temperature guage
my temperature guage will read normal at slow speeds but goes to cold on high speeds.even reads the same running the a/c
07-27-2014, 06:44 PM | #2 |
Cluster King
Re: erratic temperature guage
What you describe sounds like a normal condition for these trucks. When you are moving at 50-60 mph, you get much more air flow through the radiator which helps cool the coolant. If you are just sitting at an idle, it is normal for the temp to be higher because there is no air flow.
You won't really notice a big difference in temp with the A/C on or off. The A/C compressor only robs about 20 horse power form the engine. That will effect your fuel mileage but not your temp. Hope this helps.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
07-27-2014, 07:13 PM | #3 |
Truck junkie
Just to add to what TBONE said. If your truck doesnt have a fan shroud it exaggerates the difference.
07-28-2014, 11:22 AM | #4 |
do you have a thermostat in it?
driving 60 mph on a sub-zero day your truck should still be in the normal range check your thermostat; it may be missing or stuck open
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
