08-14-2014, 11:01 PM | #1 |
blazer chassi/ C-10 chassi?
In 20 yrs I've owned over a hundred 67/72 trucks, a few burbs and only 1 blazer. I've seen this topic on here before but past it off,
Is there a difference in the 2 chassis I know a guy w a 4x4 blazer, my long time dream has been to build a 2wd blazer. Next ? will the 1/2 ton truck suspension bolt up to the 4x4 blazer chassi? thanks Donnie
Things happen for a reason! |
08-14-2014, 11:24 PM | #2 |
Re: blazer chassi/ C-10 chassi?
I was able to do it started out with this
08-14-2014, 11:25 PM | #3 |
And ended up with this,
08-15-2014, 08:52 AM | #4 |
So the answer to the question is?? Is there a difference in a blazer chassi verses a C/10 1/2 ton chassi swb ???
By the way, that a nice blazer you have built sir grande71
08-15-2014, 09:28 AM | #5 |
From what I understand you can bolt the front suspension up. The rear is shaped differently and will take more effort, although you can simply use the leaf spring suspension if you want.
I do believe Porterbuilt may have some experience with this swap and may have packages that will assist you depending on how deep you want to do.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-15-2014, 10:17 AM | #6 |
Moderator
Contact Livrat. He has done several and can probably give you more details. From what I have read it is not a simple task, as stuff does not just bolt in directly. Makes sense to me, otherwise I would think a lot more people would be doing it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
08-15-2014, 10:57 AM | #7 |
I only found two holes that lined up the rest I had to make. It took a lot of measuring and reading thru the forum and building up enough courage to do it. I dig up the pic that shows the holes I'm talking about. Thanks for the compliment also
