Old 02-22-2015, 03:09 PM   #1
Tylerz181500
lift question
so ive been debating what to do
eventually im going full 4 link, keeping stock frame but adding tubing and such but my question is for now, since im going through somewhat of a rebuild id like to eliminate my 3" body lift and at least use a 1" for certian purposes id like to keep around 9" of lift though which means id use a drop hanger in back with my 6" springs to make it 9, but what do i do up front? do they make a 9 or 10" spring for the front, im ok with a little squat or have no problem runnign a very small block out back. or do i have to start chocking off all the brackets and relocating them downward? if i have to do that i may as well just link the front
Tylerz181500 is offline   Reply With Quote
Old 02-23-2015, 12:01 AM   #2
Re: lift question
4wd? Yes,
2wd? No, you are limited by a-arms
Old 02-23-2015, 12:06 AM   #3
Tylerz181500
Re: lift question
i always forget to mention something, geez lol
but yes im 4wd sitting at 9 inches right now, 6" spring and 3" body, id like to take at least 2" of the body out and stay around 9 so a drop shackle in rear with give me the 6+3 that i need back there but the front will be at 6" i also saw that diy4x does offer a b52 kit for pre73 trucks. so thats an option, most people say it gives around 4" o flift and then i can just use 6" rear springs up front as well? it may ride a bit rougher though, i liked the option of a soft ride spring up front but havent found anything past 6" or i could just get something custom arched.
havent looked into the b52's yet or the streetability of them so ill have to do that or inquire.
Old 02-23-2015, 09:49 AM   #4
Re: lift question
Ok, I asked because I see lift springs offered up to 12". On the front, if you use the longer 73-up springs by moving the rear mount back it's an automatic 2" lift. you could do that, use 6" springs, and an ORD zero-rate spring (block really) you would have a 9" lift w/o lifting body.
On the rear you could use a shackle-flip, either 4" or 6". I'd go 4" and the rest spring. Both methods front and rear will net the best possible ride with so much lift as well.
Old 02-23-2015, 10:34 AM   #5
57taskforce
All about them K’s
57taskforce's Avatar
Re: lift question
+1 Good advice. I was gonna say that they definitely make front springs bigger than 6" but you beat me to it. Good advice on the shackle flip as well!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 02-23-2015, 12:37 PM   #6
Tylerz181500
Re: lift question
who makes longer ones? i was already planning on a shackle flip, i was told by multiple people that 73 springs are longer but then superlift and skyjacker said they were they same, how would i move the the rear mount back?
Old 02-23-2015, 10:15 PM   #7
Re: lift question
All '73 and newer front leaf springs are longer, just a fact. Not sure why the spring companies are giving you incorrect info. Just relocate everything rearward, I'm sure there's a thread somewhere. This is why your thread should have been posted in the 4wd and off road forum. You would get all the info you need and probably by now. I have never moved the mounts back myself.
I'm going to do you a favor and report this post as being more appropriate for that forum. Look for it there
Old 02-23-2015, 11:27 PM   #8
70LonghornCST
Moderator
70LonghornCST's Avatar
Re: lift question
Thanks Tim! I moved this to the 4WD section for you. Good luck with your inquiry.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 02-24-2015, 01:01 AM   #9
Tylerz181500
Re: lift question
apparantly being new and not used to the site has its drawbacks, thanks for moving it, and i specifically inquired to both superlift and skyjacker and had them check part number for the 67-72 truck and 73+ and they told me the part numbers for leafs were the same, regardless its not correct info which suspected so i wont base anything off it
Old 02-24-2015, 08:27 AM   #10
Re: lift question
your learnin'...you're learnin' . no worries, just trying to help. Those lift companies are messed up if they say the springs are the same. Her's a place that offers multiple brands, including Superlift & Skyjacker, to confirm the facts:
http://www.rockymountainsusp.com/lif...y-gmc/4wd.html
Let's see who pops up with info or a link on 73 springs on 72. The difference is something like 3". You could always get 69-72 8" springs, but taller the spring tighter the ride
BTW, Tuff Country knocks the socks off those companies you spoke with. And Superlift was my brand of choice before they came along.
Old 02-24-2015, 11:20 AM   #11
Tylerz181500
Re: lift question
i know tuff country is great for leaf spring lifts, i talked my buddy out of rcx for his kit to a tuffcountry because its all ord and everyone uses.
id be nterested in hearing about the 73+ springs and some b52 experience
, so if i call skyjacket i could likely get just the springs? i dont want the rest as im going crossover.
Old 02-25-2015, 08:22 AM   #12
Re: lift question
They should sell just the springs. If not, go to someone else.
Old 02-25-2015, 10:31 AM   #13
Tylerz181500
Re: lift question
thats what im thinking my buddy also said 4x4 square stock mounted under the frame rails and relocate the front hangers downwards a bit is what he usually does, anyone have thoughts on that?
Old 02-25-2015, 10:52 AM   #14
jjzepplin
jjzepplin's Avatar
Re: lift question
UHM no. Might work for a mud rig but looks downright hokey. Do it right or don't do it. My 2C.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-25-2015, 11:54 AM   #15
Tylerz181500
Re: lift question
no i agree, it was mentioned, all his have been mud trucks with the exception of one so your probably on the right track. just figured id ask since its on topic.
