01-23-2015, 05:24 PM | #1 |
What size tire on a 7" rim.
I have a set of 7" & 8" rallies and soon to be two short beds. I want to save the 8" for the one that I am rebuilding. The shorty that I am getting needs a set of rallies back on it and if I can't find a decent set of 8's then the 7's will go on. My question is that I was thinking about either running 275/60's all the way around or maybe 245 on the front and 275 on the rear. Will a 275 go on a 7" rim? I really like the fat tire look on the rallies. Right now the truck is stock height. At most if I decide to lower it would be a 2/4 drop.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
01-23-2015, 06:29 PM | #2 |
Re: What size tire on a 7" rim.
Wide tires on narrow rims wears out the center of the tread. If you can't live with that then I think 245/60 is as wide as I would go. I actually did that with no problems so maybe a 255 would live on a 7 incher.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-23-2015, 06:41 PM | #3 |
I ran 225 70 15 and 275 60 15 on a set of 7" rally's, combo looked good together put over 40,000 miles on it before I sold truck.tires wore fine.
01-23-2015, 06:59 PM | #4 |
I run a 235/70-15 on a 7" wheel, it's 28" tall
01-23-2015, 07:05 PM | #5 |
Thanks guys for the replies so far. I will have to look at a couple of pics of your trucks to see how they look. I came across Melks truck here on the forum. He is running 8" on a 2.5/4 drop with 275/60's and I like that look. I may have to see about finding another set of 8's. Keeping all options open right now. Here is Melks truck.
01-23-2015, 07:05 PM | #6 |
Diggin The SquareLife
245/60/15 would be good but is a lil shorter than a 275/60/15 I would go with a 235/70/15 if ur only gona lower it 2/4
01-23-2015, 07:05 PM | #7 |
I had also had the thought of doing the 245/60's on the 7 inchers too.
01-23-2015, 07:09 PM | #8 |
5/6 drop with 15x8 on 255/60/15 up front and 15x10 with 275/60/15 rear
01-23-2015, 08:16 PM | #9 |
01-24-2015, 05:15 PM | #10 |
Active Member
I think the 454 SS that Chevy made in the early 90's came with 15x7's and 275/60/15's from the factory.
01-24-2015, 06:39 PM | #11 |
No those are 15x8s not 15x7s
01-24-2015, 06:58 PM | #12 | |
Put the eights on the rears and the sevens on the fronts, then you don't have to find another set. Fat and skinnies.
01-24-2015, 07:31 PM | #13 |
I will see what kind of deal I can get on a set of tires and go from there. I might just put these wheels on it for the time being. 295/50/15's
01-25-2015, 02:30 AM | #14 |
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
01-25-2015, 03:41 AM | #15 |
brakenit is correct, 275/60/15 on factory 15X7 wheels. Have them on my 1990 454 SS. I used to think they were 8 inch rims also until I bought this truck and found out not so.
