Old 07-15-2015, 12:05 PM   #1
77c10
77c10's Avatar
Radiator advice
I'm looking to replace my stock radiator and electric fans. I added Vintage Air over the winter and the truck runs a little hot sitting in traffic. I'm torn between the two pictured below. Is it worth the extra $100 for the shroud?
Thanks,
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 07-15-2015, 01:19 PM   #2
rideair
Re: Radiator advice
There a reason why auto makers use them on new cars, I'm sure you know it helps direct the air across the coils. Much better.
Enjoy,
Rideair
rideair is offline   Reply With Quote
Old 07-15-2015, 02:13 PM   #3
RodsGreen10
RodsGreen10's Avatar
Re: Radiator advice
Get the shroud. If that is a 3 core champion rad with dual fans and shroud it works perfect. That is what I run on my truck!
RodsGreen10 is offline   Reply With Quote
Old 07-15-2015, 02:42 PM   #4
homemade87
Re: Radiator advice
The shroud allows air to be pulled across all the radiator coils . The first picture with out will only pull air from the area of the fan .As you can see the fan will not move any air above and below the fan at slow speeds or sitting at a red light . With the shroud would be much better for removing heat . My vote goes to getting the shroud .
homemade87 is offline   Reply With Quote
Old 07-15-2015, 04:46 PM   #5
77c10
77c10's Avatar
Re: Radiator advice
It is. What temp range does yours usually run? Do you have AC?
BTW, nice ride!
Old 07-15-2015, 04:58 PM   #6
RodsGreen10
Re: Radiator advice
BTW, nice ride!
Stays around 190-195. With High Flow 180 TSTAT. And yes it has AC. It keeps a 550 plus truck cool. I got the painless dual fan relay kit with AC. I will see if I can find a pic of it. You know how hot it gets here in TN with the heat and humidity. And thanks. Back at you looks good.
Old 07-15-2015, 04:59 PM   #7
RodsGreen10
Re: Radiator advice
BTW, nice ride!
Stays around 190-195. With High Flow 180 TSTAT. And yes it has AC. It keeps a 550 plus hp truck cool. I got the painless dual fan relay kit with AC. I will see if I can find a pic of it. You know how hot it gets here in TN with the heat and humidity. And thanks. Back at you looks good.
Old 07-15-2015, 05:11 PM   #8
77c10
77c10's Avatar
Re: Radiator advice
Thanks bro. I'm going to PF for The Rod Run in September. I'd hate to overheat while cruising the strip.
Old 07-15-2015, 05:27 PM   #9
RodsGreen10
Re: Radiator advice
Yes you will need that for sure. Hell hit me up we can meet up man. I plan on going also. Also you will need a fitting for the heat hose that runs to the top of the rad. Google 1/4 not x 5/8 hose barb. Only found two places that has them. Got mine on Amazon. You will need that.
Old 07-15-2015, 11:55 PM   #10
Domer
Domer's Avatar
Re: Radiator advice
Definitely shroud. I have the exact same radiator fan combo with shroud in my 77 with a sbc and 6-71 blower. I run a restrictor plate instead of thermostat, and it never goes above 195. Shroud helps tremendously.
Project Roxy...
Shes Bad, Low, and Blown...
http://67-72chevytrucks.com/vboard/s...d.php?t=673333
Domer is offline   Reply With Quote
Old 07-16-2015, 01:17 AM   #11
Chaplain
Chaplain's Avatar
Re: Radiator advice
OK. Sorry to high jack the thread. I'm interested. Is this simply a matter of removing the existing fan from the water pump? What about the belt? Why the 3 core over the 2?
Chaplain is offline   Reply With Quote
Old 07-16-2015, 07:57 AM   #12
77c10
77c10's Avatar
Re: Radiator advice
Walt,
Remove the fan but leave the pulley on the water pump. You can use shorter fasteners to bolt the pulley to the water pump. The belt stays the same. The 3 core has 3 rows of cores versus 2 so the coolant stays in the radiator longer and technically is supposed to cool better. I pulled the trigger and ordered mine last night.
Old 07-16-2015, 09:41 AM   #13
RodsGreen10
Re: Radiator advice
You will enjoy it. This is when I was in the process of a under the hood refresh/update.
Old 07-16-2015, 11:03 AM   #14
Chaplain
Chaplain's Avatar
Re: Radiator advice
From where and how much?
Old 07-16-2015, 11:13 AM   #15
77c10
77c10's Avatar
Re: Radiator advice
I sent you a PM.
Old 07-16-2015, 10:30 PM   #16
BamaDave
Re: Radiator advice
Hey, PM me that info too if you don't care. Thanks
BamaDave is offline   Reply With Quote
Old 07-17-2015, 08:11 AM   #17
77c10
77c10's Avatar
Re: Radiator advice
I guess it's not really a secret. I got it from eBay for $367.95 with shipping included.
Old 07-17-2015, 08:29 AM   #18
RodsGreen10
Re: Radiator advice
I got mine from championradiator.com. Which is a dealer of champion radiators. It is led foot racing. I got the rad the shroud and overflow tank plus got everything polished and shipped for $599.
Old 07-17-2015, 10:09 AM   #19
Domer
Domer's Avatar
Re: Radiator advice
I got mine on eBay for $380 with free shipping. Wasn't polished though. That was radiator 3 core, fans and shroud.
Project Roxy...
Old 07-19-2015, 11:39 AM   #20
Lil Ape
Re: Radiator advice
Anybody got a ebay link to these radiators? Or the core dimensions?
Lil Ape is offline   Reply With Quote
Old 07-19-2015, 11:54 AM   #21
RodsGreen10
Re: Radiator advice
This is who I got mine for they have it on sale for $209. All the specs are listed.
http://www.championradiators.com/Che...core-1987-1991
Idk why the link say 87-91. It is for 73-91. But the one I got was part# CC161.
