12-28-2015, 11:30 AM | #1 |
My 62 SWB AKA Plausible
So after months of posting my pics on facebook and following Bomp he caught wind and sent me a friend request and told me I should put one of these together.
So here it goes. I picked up my 62 SWB small window in June. I'm going to attempt to link from facebook so if the pictures don't work I'll try to fix manually. My goal for the truck is to perform the rust repair on the cab (tall order)...remove the "aftermarket" body lift and get it on the road. The first goal was to support the cab and remove it from the frame. Then we got to cutting out (some) of the rusty areas. The previous owner had an interesting method of patching the wholes. It typically involved tin and silicon. More to come. Last edited by rpone605; 11-25-2016 at 02:28 PM. Reason: Updating title |
12-28-2015, 12:04 PM | #2 |
Re: My 62 SWB (Bomp made me do it!)
The first major chunk of rust repair was done on the passenger side. Someone had already started working on the cab and had cut out the inner and outer rockers. Here's how the passenger side currently looks.
Then I started working on the driver side. It currently looks like this but with the upper floor support. The next big project on the cab is the rear of the back floor and wall. I was able to find a good donor piece for it. This required us to flip the cab over and support it by the cowl and the back so the roof wasn't on the ground. This pic is after we cut up the donor piece and put the replacement back wall skin on. |
12-28-2015, 12:04 PM | #3 |
Oh please let me know the pics are working so I don't keep posting and have to fix a bunch of image links.
12-28-2015, 12:08 PM | #4 |
NOPE, No pics.
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
12-28-2015, 12:15 PM | #5 |
Welcome. I got pics, looks like good progress.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
12-28-2015, 12:20 PM | #6 |
I wonder if it only works if someone is logged into facebook
12-28-2015, 12:44 PM | #7 |
1961 crewcab
I can see them, and I am not logged into fb.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-28-2015, 12:48 PM | #8 |
Ok then. I'll take 2-1 odds on it working haha.
12-28-2015, 02:12 PM | #9 |
3:1 working.
Welcome. Thanks to Bomp for forcing you...... He is a bit like that. You have a load of work ahead of you, but came to the right place.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
12-28-2015, 06:39 PM | #10 |
I know why, I was at work and Facebook is blocked. Didn't put the two together until now. Nice project!
12-28-2015, 10:24 PM | #11 |
Welcome lots of great people here. Lots of resources to pull from as well. Look forward to watching your project.
12-29-2015, 09:55 AM | #12 |
Thanks for the words.
One quick question/input requested. I'm currently using this welder http://www.harborfreight.com/welding...der-61849.html (on loan from a friend) for welding duty. While I know it's not the best welder in the world it has served it's purpose for the most part. The problem I am running into while welding the back panel is that it keeps blowing holes through the metal. From what the harbor freight site said it should be able to handle 18g. However the welder seems to be running too hot. I could probably get my hands on a nicer lincoln with argon. Would it make the welding that much better/easier? |
12-29-2015, 08:55 PM | #13 |
As much metal work as you are doing IMO would really prefer better welder with argon much cleaner welds. I started welding on my truck learn as you go method. The flux core tended to spatter more making a bigger mess for me to clean up.
12-29-2015, 09:09 PM | #14 |
That's kind of what I was thinking. Thanks for the feedback.
Posted via Mobile Device |
12-29-2015, 10:49 PM | #15 |
A better welder with more heat control will help with welding sheetmetal. Also check out MP&C's build http://67-72chevytrucks.com/vboard/s...d.php?t=564201. He shows some great metal working techniques.
12-30-2015, 02:10 PM | #16 |
and welcome aboard… Glad you listened to Bomp...
I'm along for the ride and agree with the previous welder posts… I bought a used HF welder from a friend, it died, so I picked up a hobart with an argon bottle and have learned a lot along the way… This is a great site with great folks and I can see the pics... Along for the ride...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
01-04-2016, 09:46 AM | #17 |
One quick update. It's been busy the last few days so not much got done.
I was able to borrow a different welder that's gas and it's much nicer to weld with. I did some more spot welding on the cab and I think it came out pretty good. I hope to get out there in the next day or so and do some grinding and try to get the back of the cab wrapped up this week. BTW this only took me about 20 minutes to do. With the other welder this would have taken me hours. |
01-04-2016, 02:40 PM | #18 |
Welcome and glad to see you started a thread.
One thing to remember is to prep the area thats needing to be welded. ie. clean metal til its shiny. Nothing wrong with taking it slow. -reduces warping- I read MP&C, and many others. http://67-72chevytrucks.com/vboard/s...d.php?t=564201 I admire your courage to jump right in and make it right. Sub'd |
01-04-2016, 03:08 PM | #19 |
I typically try to hit the areas with a flap disk before I start and then start welding.
01-12-2016, 09:49 AM | #20 |
Just one update. I took the plunge and picked myself up a new welder.
Figure I would spend a little more and get something that would last and do everything I needed. |
01-12-2016, 11:18 AM | #21 |
Congrats, You're going to love that Millermatic 211
01-12-2016, 11:52 AM | #22 |
It's been pretty awesome so far. Way easier to use.
01-29-2016, 10:28 AM | #23 |
Just one quick update. Been fighting the corner and ended up really unhappy with how it turned out. So I decided to start over with that section since it really didn't turn out the way I hoped.
I haven't tacked the new piece in yet. Still working on fit and finish but it's pretty close now. |
01-29-2016, 12:11 PM | #24 |
Great progress… Keep up the amazing work!!!
01-29-2016, 06:15 PM | #25 |
I'll Be watching this build also. I'm about 3 hrs south of you. Ray
