Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 10-10-2016, 04:26 PM   #1
Lblevins
1967 c40
Ok I bought this cause I have a bunch of classic cars and wanted a big truck. I have had a few thoughts on things i'd like to do like a front steer setup with a rack-n-pinion, 5.3 ls and th400 which I already have all. truck will not ever be used for hauling any real weight etc. Anyone have any advice on steering or anything else. More than likely the truck will end up with air ride also. Anyway, this is the only resource I have found with anyone doing anything to the larger trucks so any pointers im all ears.
Lblevins is offline   Reply With Quote
Old 10-10-2016, 09:17 PM   #2
rkn463
rkn463's Avatar
Re: 1967 c40
If you will never haul much then you might want to consider swapping out to a lighter 1 ton frame and running gear. Then if you want the big truck dual wheel look you can get adapters to mount the larger 10 hole 18 wheeler wheels. You'll find all of your brake and steering parts all way easier to source. My personal preference is to keep them as medium duty trucks but they are hard to find parts for, slow and rough riding, but to each his own! How about some pictures of what you are working with?
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 10-10-2016, 09:30 PM   #3
Lblevins
Re: 1967 c40
Use to be an air force truck.
Old 10-10-2016, 09:43 PM   #4
Lblevins
Re: 1967 c40
-Richard
Your not too far from me. I am in southern oklahoma. I do classic car restorations.
Old 10-10-2016, 10:19 PM   #5
rkn463
rkn463's Avatar
Re: 1967 c40
Good looking truck, that should make a cool project. Do you have a web site for your restoration business?
-Richard
Old 10-11-2016, 09:14 PM   #6
Lblevins
Re: 1967 c40
I forgot I have this 1 ton with all new steel screw bushings etc I can pull the front and rearend out of with all the brakes to go into my 67..
Old 10-11-2016, 09:51 PM   #7
rkn463
rkn463's Avatar
Re: 1967 c40
I forgot I have this 1 ton...
I can relate!
-Richard
Old 10-11-2016, 10:48 PM   #8
Lblevins
Re: 1967 c40
Anyone have any idea if this 67 cab will fit the 83 1 ton frame?
Old 10-12-2016, 12:05 AM   #9
Softpatch
Softpatch's Avatar
Re: 1967 c40
Not sure.? But would like to see that.!
I think it would be easer to put parts from 81 onto the 67 rails
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 10-12-2016, 12:11 AM   #10
Lblevins
Re: 1967 c40
That's what i'm leaning towards. I plan to take some measurements tomorrow though to check.
