11-06-2016, 10:11 AM | #1 |
Frame off help needed...
A friend with a 68 step side finally got his powder coated frame back after 9 months (wow)and most of the chassis bolts are not to be found.
For a start: 1) What size bolts are for the engine cross member and torque 2) Where to find the 4 upper control arm shaft bolts This friend knows "nothing" and for me, just a pic and information and I believe I can help him. You guys have helped me before and I hope you will bare with me on this one. Thanks Ed...
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
11-06-2016, 11:16 AM | #2 |
Re: Frame off help needed...
If by engine cross member you mean the main cross member that goes under the engine, it takes 7/16-14 by 1" grade 8 bolts lock washers and nuts. Check the LMC catalog for the cross shaft studs. Purchase a 67/72 Truck Assembly Manual. It will be invalulable in your friends re assembly process. Torque for the bolts can be found in the manual but I think it is 55-65 ft lbs.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
12-25-2016, 01:02 PM | #3 |
Does anybody have any input to what these spindles came off of and what year...
39RHGM 264 6274264 F288 34LHGM 263 6274263 F289 Going to be doing a front drum to disk conversion on a '68 and not sure if they will work and what size inner and outer bearings to use. The caliper#'s with spindles read: 2L K18007152GM 7R 5474177 Thanks Ed
12-26-2016, 02:46 PM | #4 | |
At this point it seems that the spindles fit 73-87, does this list seem right and complete or am I missing something? 1. 73-87 upper and lower ball joints 2. 73-87 outer tie rod 3. 68 outer tie rod (to use as inner) 4. Use Classic performance CP4SC_SAR reducing tie rod sleeves (11/16" to 5/8") 5. Use existing 68 drag link
12-28-2016, 07:24 AM | #5 |
ttt
