Old 05-15-2017, 04:28 AM   #1
5spd540
6 spd on a 327
Does anyone know what would be involved in putting a t56 from a 2001 camaro in a 71 c10 with a 327 in it?
5spd540 is offline   Reply With Quote
Old 05-15-2017, 07:22 AM   #2
Overdriven
Re: 6 spd on a 327
http://www.lateral-g.net/forums/showthread.php4?t=20916
The link is the first thing that comes up in a google search. It's an older post but provides methods for reusing stock mechanical clutch linkages and clutch components as long as the spline count is correct.
If you're starting with no original clutch components in the truck or just want to go hydraulic on the clutch I'd go with the SBC Gen1 to LS1 T56 specific bellhousing from QuickTime. No adapter plates or other nonsense needed.
Overdriven is offline   Reply With Quote
Old 05-15-2017, 07:34 AM   #3
67 chevelle
67 chevelle's Avatar
Re: 6 spd on a 327
Its involved , make sure in advance whether you have a t56 from an ls1 , or lt1 , huge differences , like input shaft length , also be aware the lt1 components will not retrofit , a special flywheel will be required , your engine has a 2 piece rear seal , the lt1 has a one piece . Get the number off your transmission tag , and call american powertrain , they will lead you in the right direction .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-15-2017, 09:06 AM   #4
5spd540
Re: 6 spd on a 327
It is a LS1 trans. I will start with this info. Thanks
Old 05-15-2017, 09:57 AM   #5
67 chevelle
Re: 6 spd on a 327
The reason I posted "also be aware the lt1 components will not retrofit" is because many would assume small block to small block , easy peasy , but the differences in rear seals and weighted vs non weighted flywheels , requires a special flywheel . I had a t56 in a 68 camaro , luckily it had a one piece rear main [newer motor] so this was not an issue , but my buddy has a 32 ford with an older sbc , and 96 t56 from a camaro , he had alot of issues .
Old 05-17-2017, 03:40 AM   #6
5spd540
Re: 6 spd on a 327
Anyone have any pics of where the shifter will be in relation to where the seat sits? I thought about this due to the length of the trans. Also does anyone know how much of if any will have to be cut out of the tunnel to make it fit?
Old 05-17-2017, 08:02 AM   #7
67ChevroletDude
67ChevroletDude's Avatar
If you do a search on here it should pull up some good reading. From what I read the shifter pops out at about the front of the bench seat and you can't do much so you have to relocate it farther forward. If it's a high or low hump it will fit, if you have a low hump you will need to take a portion that's a little larger in diameter than the shifter to snug it up closer.
67ChevroletDude is offline   Reply With Quote
