Old 06-20-2017, 06:29 PM   #1
Boydc10
Disc brake upgrade bearing question
Trying to finish up my brake upgrade on my 64. I have a crossmember from a 85 C10. Using the stock spindles (1.25 shaft) and 6 lug rotors from cpp. My question is which bearings to use. The A5 set fit the rotor but too big on the spindle shaft. The A6 set fit he spindle shaft but too small for the rotor. Thanks for any help.
Boydc10 is offline   Reply With Quote
Old 06-20-2017, 11:35 PM   #2
Captainfab
60-66 Nut
Re: Disc brake upgrade bearing question
Did those spindles originally have 1" thick rotors or the 1.250" thick rotors?
Old 06-21-2017, 10:36 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I agree with Captainfab, those years have two different spindles. A light duty and heavy duty. I think that started around '81 or so. Everything earlier would be the heavy duty ones and most of the companies making stuff are using the heavy duty versions.
You need to figure out what spindle you have.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-22-2017, 09:30 PM   #4
Boydc10
Thanks for the replies. I found out the donor truck had 1 inch rotors so I got some different spindles ordered. Thanks again.
