Old 07-20-2017, 05:19 PM   #1
Mossbeard
66 TH400 transmission question
Is this normal?
I have a TH400 behind a 327 in my '66 C20. When I shift from park to drive (or reverse) the whole vehicle lurches and there's a thump like I've been rear-ended.
If not normal, where should I start investigating?
I was under the truck recently (fuel leak) and the drive shaft had no slop in it.
Also, the last time I drove the truck I stayed below 45mph but I remember feeling like it wasn't shifting. I don't have a tach but the engine seemed to be revved high. At what speed (roughly) should I expect to feel a gear change?
Mossbeard is offline   Reply With Quote
Old 07-20-2017, 08:45 PM   #2
yelmer
Re: 66 TH400 transmission question
check the fluid level truck must be running
yelmer is offline   Reply With Quote
Old 07-21-2017, 01:21 PM   #3
Dead Parrot
Possible a u-joint failed since you were last under the truck. Chock the tires on level ground, trans in neutral and check for slop again.
Check the springs and associated bushings, perches and such for correct and tight.
Is it possible the indicator is off and you were really in L2?
Dead Parrot is offline   Reply With Quote
Old 07-21-2017, 06:43 PM   #4
YoungPup1977
the PR spring scenario again...be careful....may break the pump gears in the transmission.....
YoungPup1977 is offline   Reply With Quote
Old 07-22-2017, 04:13 AM   #5
goofy063
check the vacuum hose going to the modulator valve a vacuum leak will cause high idle and delayed shift
goofy063 is offline   Reply With Quote
Old 07-31-2017, 01:36 PM   #6
mattfranklin
mattfranklin's Avatar
Is your idle speed too high?
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 08-02-2017, 11:51 AM   #7
rideblue00
rideblue00's Avatar
any updates?
rideblue00 is offline   Reply With Quote
