07-14-2019, 12:36 PM | #1 |
80' transfer case
My 80' locked up in 4wd a number of years ago and after I got sick of driving
it that way it was parked in the barn. Now its time to fix it or let it go. I remember before it broke having one hell of a time shifting out of 4wd. I believe that the fork pin may have been sheared off. Can the problem be confirmed or diagnosed further visually, without removing it from the truck ??? |
07-14-2019, 01:42 PM | #2 |
Re: 80' transfer case
ah i see a felow rust belt member of upstate ny . . . were at ? i am in horseheads by he ny/pa boarder half way across the state .
need more info on your t-case . cast iron or aluminum ? shifter indicator on the floor show 2h/4h/n/4low or have lock positions ? if the case is not that slimy look for a round tag on the back or a square tag on the front . 203/205/208/241 models were used .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
07-14-2019, 02:46 PM | #3 |
80 is the year where every 4x4 got the Np205. Could have been swapped out in 39 years though.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
07-14-2019, 10:44 PM | #4 |
it should be a 205. if it is, the shifting mech is on the pass side front, should be able to get some prybars in there possibly to try to loosen or move it. might need to be soaked with some pb first though.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
07-15-2019, 01:30 AM | #5 |
If the transfer case needs to be dropped can it come out with the
transmission attached ??? Matt, its all factory, I am the first owner. |
07-15-2019, 01:37 AM | #6 |
it could...but youll find it much easier, and a lot lighter , to separate them..together theyd be bumping 300lbs and very awkward weight balance
07-15-2019, 11:14 AM | #7 |
if it is the 205 for sure then i have played with a lot of them and built a lot .
grab some good light oil and lube the shift rails were they go in the case . grease the shifter bolt if it has a fitting . make sure the locking hubs are unlocked as this can sometimes bind them up . these 205 cases like lube and shift a bit funky or bind up when dry in the above said points . dont forget 4low in or out the trans needs to be in neutral and truck stopped .
