10-17-2023, 04:25 AM | #1 |
What was the factory tire size on 87?
I'm about to get new tires on my 87 2wd half ton silverado. But the tire shop seems a bit confused on what size would have been factory. I'm hoping someone here can tell me the size that would have come on the truck when it was new. It's just got the typical 15" rally wheels. Thank you
10-17-2023, 07:26 AM | #2 |
Re: What was the factory tire size on 87?
Base was P195/75R15.
You could order up to P235/75R15. There also was an LR60-15B available within certain packages. K https://www.gm.com/content/dam/compa...olet-Truck.pdf
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-18-2023 at 10:19 AM. |
10-18-2023, 12:13 AM | #3 |
Thank you sir
10-18-2023, 09:33 AM | #4 |
There should be a sticker on the door with the original size and recommended psi. (not the VIN sticker)
John '91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's |
10-18-2023, 10:16 AM | #5 |
Speaking of stickers: An optional tire will also appear on the SPID if you still have the label in the glovebox.
Tire RPOs are Xxx (front), Yxx (rear) and Zxx (spare). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-19-2023 at 12:44 PM. |
10-19-2023, 10:36 PM | #6 |
What are the characteristics of both these tire sizes? It would seem that the larger tire was considered to be an upgrade. Was there no advantage to the smaller tire?
10-19-2023, 11:42 PM | #7 |
Ride height and engine speed. Smaller tire = lower stance and faster engine RPMs. Larger tire = higher stance and lower engine RPMs. Also will impact the speedometer accuracy.
10-20-2023, 08:19 AM | #8 | |
As a manufacturer you take the cheapest tire you can offer and use that as base. Any tire savings is multiplied by 5 (or by 4 for those vehicles that do not get a spare) so it adds up. Yes - the larger tire is an upgrade and therefore additional cost to the customer and more revenue for GM. Tire prices are shown in the info packet I linked; it cost me an additional $250 to opt up to the P235 tires on my '87. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-20-2023 at 08:27 AM. |
10-20-2023, 09:06 AM | #9 |
So if you opt for the larger tires what was done to correct speed and mileage?
10-20-2023, 11:13 AM | #10 | |
https://67-72chevytrucks.com/vboard/...d.php?t=845046 Page 42 of this PDF shows the different tire sizes that were available https://www.gm.com/content/dam/compa...olet-Truck.pdf
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
10-20-2023, 11:47 AM | #11 | ||
The GVWR is established not only by how much weight the vehicle can carry, but also if you can get that weight moving and stopped. That includes rear axle ratio, too. When I was establishing GVW (and GCW) ratings the final capping run was if you could get the load moving up the 16% grade at the Milford Proving Ground from a standing stop. Quote:
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-20-2023 at 11:52 AM. |
10-23-2023, 08:52 AM | #12 |
What size tires have you got on it now that the tire shop is 'confused'?
10-24-2023, 10:48 AM | #13 |
How wide were the rims with the p235’s, Kieth?
10-24-2023, 03:36 PM | #14 |
15 x 8 rallys.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-27-2023, 04:22 PM | #15 | |
Junior Member
I thought I wanted blackwall and after the fresh paint job I purchased a complete set of the Goodyear Wranger Duratrac to get the Outlined white letter tires. I am not sure where you are in Texas but I am an hour out of Houston on the east side. |
11-04-2023, 08:36 AM | #16 | |
