02-06-2015, 04:36 PM | #1 |
Project "Moonshiner" Bagged & Z Frame 63
Well, guess I'll jump in with a build.
I picked up this 63 short fleet, big back window for a candidate. I got it from a garage/junk-yard for $800 Here's pics from the junkyard and after I got it home (Toyota wheels and all) |
02-06-2015, 04:44 PM | #2 |
Re: Project "Moonshiner" Bagged & Z Frame 63
The original 6-cyl supposedly ran when it was parked 4 years ago, but a SBC is in it's future.
The cab is actually in pretty good shape. I have some good usable front fenders to replace the ones on it. The bed's not real bad. Needs all new wiring. I found some original wheels for it on Craigslist, so on they go and into the garage. At some point in it's life (looks like a long time ago) it was in a front end collision. The frame was straightened but the front horns were torched off about 3" short. There's some fairly nasty frame work that went on, so this seems like the perfect candidate for a Z by someone who's never done one. |
02-06-2015, 04:49 PM | #3 |
I picked up step notches from Suicide Doors so I started there first.
02-06-2015, 06:18 PM | #4 |
Nice project!!
02-09-2015, 05:24 PM | #5 |
I ordered heim joint bung ends to build a panhard bar, and shocks are gonna be last.
____________________________________________ My build thread: Project Moonshiner Bagged & Z Frame 63 http://67-72chevytrucks.com/vboard/s...d.php?t=659205 "I love the smell of grinding metal" |
02-14-2015, 01:34 PM | #6 |
Getting ready for the Z cut. Since I'm working by myself, I figured a engine hoist with a leveler would be the easiest.
02-14-2015, 01:37 PM | #7 |
I'm going to add a fish plate on the inside of the frame too. I just haven't done it yet.
02-14-2015, 01:45 PM | #8 |
Front part just tacked on now until I mock up the front sheet metal to make sure its in the right spot.
Notice the front frame horns? At some point in it's life, from the repairs I'm guessing a long time ago ,this truck was in a front end wreck. Front horns were torched off and one frame repair was done with very sloppy stick welds. I cleaned up the weld the best I could and rewelded it. You can see it a little in this pic just behind the steering box. The angle iron on the front was just to keep the horns straight so they could be put back on both at the same time.
02-14-2015, 01:51 PM | #9 |
I wish I could have at least pressure cleaned the frame, but by the time I got a chance to start on it, it was already getting too cold out. As soon as it warms up I'll pull it back out and clean the frame.
02-22-2015, 04:57 PM | #10 |
One of my LCA's caught a manhole cover or something. A 4-ton porta power fixed it pretty easy. I thought I had a picture of that but I guess not.
Got the bump stops off.
02-22-2015, 04:58 PM | #11 |
02-22-2015, 08:08 PM | #12 |
One foot in front of the other
Just saw this. Looks good. Where is Paint Bank?
02-22-2015, 09:24 PM | #13 |
Craig County, in SW part of the state right next to the WV state line.
02-22-2015, 10:14 PM | #14 |
I like what you're doing, Popcorn. I was going to suggest an easier way to position the front suspension after you cut it out, but man, you work fast! We built a jig that went from the floor to the frame while it was in the stock location. After the front and rear cuts, we stacked some 2x2 square tubing under the jig and was exactly where it needed to be.
If you have any questions, PM me. I might be able to give you some tips I learned during my "Z". Keep up the good work!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
02-22-2015, 10:59 PM | #15 |
Good job, work is coming along nice
02-25-2015, 06:16 PM | #16 |
Thanks guys! Haven't gotten anything done in the last few days. It's just been too cold to heat the garage.
Thanks for the offer Chevyrestoguy I may have to get some tips from you. I checked out your build and I like that jig idea. I noticed you only had to use one u-joint on your steering shaft. I'm gonna end up using two because I'm using original non-power box in original location.
02-25-2015, 07:04 PM | #17 |
Sweet truck! Can't wait to see it layed out and I'm diggin' the name too
"Popcorn said............well you know" |
02-25-2015, 07:12 PM | #18 |
Great start.
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
02-26-2015, 01:16 AM | #19 |
You don't waste any time! Nice truck, keep it up.
1963 Destiny Build Log |
02-26-2015, 10:55 AM | #20 |
Z-chop turned out nice!
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
02-26-2015, 12:02 PM | #21 | |
Hope this was helpful.
02-26-2015, 06:48 PM | #22 |
Registered Loser
Looking good! Looks like a decent truck for a junk yard find.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
02-27-2015, 09:38 AM | #23 |
Thanks everyone. And, chevyrestoguy, I went through a lot of the same double-d mods with a frame swap I did a few years ago. I had a spare S-10 column that I used for parts and bought a new plain DD shaft from Speedway for extra length.
02-27-2015, 09:45 AM | #24 |
I like where this is headed! Ill be watchin' fer sure! Carry on...carry on! Hahaha
64 LWB to SWB Step build. Daily driven! http://67-72chevytrucks.com/vboard/s...d.php?t=647168 |
02-27-2015, 09:45 AM | #25 |
For the front I'm trying something completely different. If it works, great. If not I'm gonna be the Forum Idiot.
I got this idea from a post that Chevy Mike had about a truck he had. I asked him about it and these LCA's were made by a company in CA years ago before drop spindles were available. He said they worked okay except if you hit a hard bump it would damage the upper ball joint because of the extreme angle of the upper control arm.
