11-18-2017, 06:55 PM | #1 |
3 on the tree
Any one know where to buy new column or a rebuild kit for a three speed manual shift , also new linkage. truck shifts ok but a little slow and lots of slop
thanks for ant input |
11-18-2017, 09:43 PM | #2 |
Re: 3 on the tree
Check/replace the bushings on the linkage at the shift rod ends.
11-20-2017, 10:24 PM | #3 |
Re: 3 on the tree
thanks I will check them out
12-13-2017, 12:01 PM | #4 |
Re: 3 on the tree
LMC sells these. Start here and then look further into the catalog under transmission section: http://www.lmctruck.com/icatalog/cc/t.aspx?Page=56
Also make sure you look under the correct Year and Make section of your truck. The link above is for a '73. |
12-15-2017, 03:40 PM | #5 |
Roadside Rebuilder
Re: 3 on the tree
Hey there! Before you go buying anything, try this: http://67-72chevytrucks.com/vboard/s...d.php?t=215307
