01-12-2018, 05:34 PM | #1 |
'68 C60 temp gauge
Hello! I've been creeping around the forums for years and finally made an account. I have a '68 C60 farm truck with a 366 in it. The temp gauge never worked when I got the truck, but if you touch the sending unit wire to ground it pegs hot, so I know the gauge works. Being a C60 I couldn't find a sending unit listed for it anywhere. Working with my local NAPA guy we found a sending unit out of a 68 2500 396 truck that looks identical, but after installing it today the gauge still never gets off cold. Does anybody know what the resistance cold/hot should be for this truck's sending unit? Anybody know of where to get the right one? Any other ideas?
This is the sending unit I have now: https://www.napaonline.com/en/p/ECHTS6469 ~EDIT the old sending unit says "AC-Made In U.S.A.-12 VOLT" but I don't see any part numbers on it. Thanks!
Lance '88 RCLB K1500 Scottsdale Original 305/5spd 325xxx miles.(Build Thread) '56 Studebaker C-Cab Pickup 259 V8/4spd (Build Thread) '80 Chevy Luv 4x4 (Build Thread) '68 Chevy C60 366/5+2 Dump Bed Last edited by Triplel40; 01-12-2018 at 06:22 PM. |
01-12-2018, 07:49 PM | #2 |
The Older Generation
Re: '68 C60 temp gauge
There are two different sending units, one for the idiot lights and one for the gauges. I bet you have the wrong one. I can't tell you what the ohm readings should be but I would bet it's the sender..... Nice looking truck! LockDoc
01-12-2018, 08:06 PM | #3 |
Dude with the dual thermostats and the huge radiator, it may never get warm! LOL!
But LockDoc is right. Some of those had an idiot light AND a gauge. One on each head.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-13-2018, 01:22 PM | #4 | |
Check the wire and make sure it is not damaged. Basically your temp gauge is an ohm meter, so anything affecting conductivity will make it read wrong. When I first got my 68 back together I was reading cold or barely registering. My wire had been cut and was twisted together and taped, when I fixed it with solder and heat shrink the problem was resolved. -Richard
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
01-15-2018, 03:03 AM | #5 |
Definitely have the right sending unit between the two options I found. I stripped the insulation back off of the wire and it is pretty badly corroded inside. I'll run a new wire to the gauge tomorrow and let you know what happens!
Lance '88 RCLB K1500 Scottsdale Original 305/5spd 325xxx miles.(Build Thread) '56 Studebaker C-Cab Pickup 259 V8/4spd (Build Thread) '80 Chevy Luv 4x4 (Build Thread) '68 Chevy C60 366/5+2 Dump Bed |
