Old 02-03-2018, 07:49 AM   #1
brown7373
brown7373's Avatar
Installing engine parts on painted surfaces
I am finishing the 350 crate engine for my 72. Can I install the exhaust manifolds to painted surface on the engine or should I remove the paint? Same question for oil filter with contact surface on engine painted.
brown7373 is offline   Reply With Quote
Old 02-03-2018, 08:12 AM   #2
Perpendicular
Re: Installing engine parts on painted surfaces
I have always cleaned that area. My thoughts were the paint will only give you some uneven surfaces which can cause leaks and when you take off what you put on (I.E. the oil filter) it will take the paint off anyway.
YMMV though
-Paul
Perpendicular is offline   Reply With Quote
Old 02-03-2018, 08:27 AM   #3
You want metal to metal.
Old 02-03-2018, 05:33 PM   #4
bill3rail
bill3rail's Avatar
You want Gasket metal to metal.
Corrected Maybe?
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 02-04-2018, 03:02 AM   #5
bbrriiaann1973
Should be bare metal
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 02-04-2018, 08:06 AM   #6
Originally Posted by bill3rail View Post
Corrected Maybe?
Yes, metal to metal on mating surfaces, with gaskets where required.
