Old 01-26-2018, 11:33 AM   #1
riz
drop, flip, shocks?
I have an 81 C10 with McGaughys 4.5/ 6 drop with flip kit... shock extenders... will these shocks work for my set up? Both are stock shocks/ not dropped shocks.
Bilstein B6 4600 rear - 24-009331
Bilstein B6 4600 - front - 24-192941
Would like to order today.
Thanks in advance.
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 01-26-2018, 12:51 PM   #2
Rich84
Rich84's Avatar
Re: drop, flip, shocks?
Stock shocks with extenders...Drop shocks without.
Rich84 is offline   Reply With Quote
Old 01-26-2018, 01:32 PM   #3
riz
actually I only have rear extenders..... I was told to still use stock fronts, not dropped..... they cost a lot and want to make sure before I pull the trigger and order them.
RIZ
81 C10 short box
82 K5 Blazer
Old 01-26-2018, 01:39 PM   #4
Rich84
Rich84's Avatar
I have a 4.5" drop in front with stock shocks..no problems.
Old 01-28-2018, 12:17 AM   #5
bbbc10
Diggin The SquareLife
I had to have drop shocks on rear with shock extenders and front I just had drop shocks
bbbc10 is offline   Reply With Quote
Old 01-28-2018, 10:51 AM   #6
bigarmzz
bigarmzz's Avatar
mine is lowered 5/6 and this is what i did for shocks and didn't rob the bank
(2) KYB 344068 front (stock length)
(2) KYB 344072 rear (stock length) i used shock extenders on rear
you'll have bout $100 total with shipping from www.rockauto.com not bad considering these are KYB's and i was fine with stockers on front with 2.5" spindles/2.5" springs up front
this combo works for member ultrahd4me in most all of his builds
bigarmzz is offline   Reply With Quote
Old 01-28-2018, 05:32 PM   #7
Nick_R_23
Nick_R_23's Avatar
If you only have a 2" or less spring drop in the front and the rest of the drop is in the spindles, you can use stock front shocks. If you have shock extenders in the rear, you can use stock shocks in the back as well.
