Old 01-04-2018, 12:01 PM   #1
robnolimit
robnolimit's Avatar
No Limit Square Body 4-bar
We have now finished our first production run of Square Body FatBar 4-bar systems. Two years of testing and fitment checks have paid off well. This may be our best FatBar system yet, with the ride height, roll center and anti-squat matched perfectly to the truck.
These kits are as complete as we could make them to help with an easy install. All of the chassis side brackets fit OE holes in the chassis. An aluminum 'C' notch template (no flimsy paper) makes locating the notch cut easy and accurate. All hardware is grade-8. You get: Chassis side 4-Bar mounting brackets, integrated 'C' notch with upper coil-over mounts, notch brace crossmember with panhard bar mount and brake line tab, Axle mounts for coil-overs, 4-bars and panhard mount, FatBars and panhard bar with stainless adjusters, Coil-over shocks and springs and all hardware and instructions. The complete kit is priced at $1590.
There are a few things to note.
* Ride height is adjustable. Drop from stock height is appx 4" to 7"
* This kit fits Short bed and Longbed, but not Blazer. We are working on it.
* The four bars and coil-overs are outboard. Total space required is 4" out from the frame. this is about 3/4" more room than the leaf. You can widen the tubb to get 16" of tire clearance.
* The front 4-bar mount locates to the front side of the OE leaf mount holes. This is needed to fit the longer bars to get the geometry correct. Due to the bar length, OE "outboard" mounted fuel tanks will NOT fit.
* Yes, your forum discount applies.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-04-2018, 08:00 PM   #2
SCOTI
SCOTI's Avatar
Re: No Limit Square Body 4-bar
Nice.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-05-2018, 01:44 PM   #3
tinydb84
tinydb84's Avatar
Looks nice. Any installed pics?
David
Instagram: myfabguy
Old 01-07-2018, 05:44 PM   #4
dec010974
dec010974's Avatar
No Limit makes it hard to decided what suspension is best. They have som many good options that are reasonably price.
dec010974 is offline   Reply With Quote
Old 01-08-2018, 04:25 PM   #5
moregrip
moregrip's Avatar
this looks awesome! same relative performance from 4" to 7"?
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 01-20-2018, 02:24 PM   #6
Goats86
Rob, Do you have any installed pictures? I am running a 31 gallon blazer fuel tank and needing to see if this will fit in with the tank.
Goats86 is offline   Reply With Quote
Old 03-20-2018, 09:27 PM   #7
Goats86
What is the forum discount?
Old 03-21-2018, 10:07 AM   #8
robnolimit
robnolimit's Avatar
Yes. Because our bars are adjustable (multiple mounting points) you can get the I.C. and Anti-Squat in range at varying ride heights.
Old 03-21-2018, 10:09 AM   #9
robnolimit
robnolimit's Avatar
There is about 24"/25" from our crossmember back for a tank. It would be close. If you still have the OE brake line tab/arm holding your brake line (out from the chassis, behind the rear axle) then it would fit. Our crossmember has a tab to replace the OE arm, in the same location.
Old 03-21-2018, 10:11 AM   #10
robnolimit
robnolimit's Avatar
10%. Also, we will be at the C10 Nationals in Ft. Worth in May. If you are going, you can place your order ahead of time and we will deliver to the show at no charge.
