04-18-2018, 10:54 PM | #1 |
Brake Problems
Hey all have a question about my brakes. Have a 1969 C2500 with brake booster equipment. When I try using the brakes the pedal goes down to the wall. The brake cylinder doesn't leak fluid and stays full. Bled brakes didn't get any air when bleeding. May have messed up when I bled the only thing I can think of since I have no fluid lose. Any ideas.
04-19-2018, 05:40 AM | #2 |
Re: Brake Problems
sounds like a bad master cylinder. It doesn't have to leak to be bad.
04-19-2018, 09:37 AM | #3 | |
Re: Brake Problems
04-19-2018, 02:51 PM | #4 |
Re: Brake Problems
Take the brake lines off the master and get some brass plugs to block the ports. Pump the brake and if the pedal fades the master is bad.
Fuzzy |
04-19-2018, 06:57 PM | #5 |
Who Changed This?
Re: Brake Problems
Your master cylinder is bypassing. If it is old, just replace it, so that you don't have to deal with a pitted bore.
