07-11-2018, 10:15 PM | #1 |
Changing rear fenders
Need to replace both rear fenders on 67 stepside truck. Is it as simple as unbolting a few screws? thanks
07-11-2018, 11:10 PM | #2 |
Re: Changing rear fenders
Pretty much yes
07-13-2018, 03:04 PM | #3 |
Go Pack Go!
I could get the bolts loose by hand so I used a cutting torch.
07-13-2018, 09:55 PM | #4 |
I drilled the center of the phillips screw head out with a twist drill a little smaller than 5/16" diameter.
Mine where very badly rusted. I think I used 9/32 (but 1/4) would have probably worked also. I drilled just deep enough to get too the back of the nut. Then when I turned the nut with a wrench it broke off clean and no damage to the fender.
07-14-2018, 12:11 PM | #5 |
Six in a row makes it go...
Good exploded diagrams on LMC truck catalog.
Not the best pics, but: 1. Bolts connecting step to fender; 2. Bolts connecting stiffening rods to bedside; 3. Bolts connecting fender to bed.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
