Old 10-22-2013, 10:36 PM   #1
ivorton74
ivorton74's Avatar
Ls swap radiator
What are u guys running for a radiator in ur trucks? I was thinking about using the stock sbc rad but is there something better i can use? Have to change it anyway because it leaks
ivorton74 is offline   Reply With Quote
Old 10-23-2013, 12:07 AM   #2
Blackpony
Blackpony's Avatar
Re: Ls swap radiator
I just used a heavy duty stock replacement for my truck.
Blackpony is offline   Reply With Quote
Old 10-23-2013, 12:54 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
Depends on budget... I would like to run an aluminum radiator with the inlet/outlet on the same side and have a provisions for a steam port... I'll start with the stock SBC radiator for now and go from there...
Rich
1972 K5 Blazer CST Click HERE
Old 10-23-2013, 01:50 AM   #4
jorgensensc
jorgensensc's Avatar
I modified the core support and used the stock radiator and dual electric fans from the donor vehicle.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-23-2013, 09:11 AM   #5
Clyde65
Clyde65's Avatar
Champion is what I used, put the steam port in the top Rad hose using jagsthatrun's adapter. the Radiator came with dual electric fans so that is what I use.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-23-2013, 02:43 PM   #6
ivorton74
ivorton74's Avatar
Can a camaro or firebird ls1 rad work?
Old 10-23-2013, 06:38 PM   #7
Andy4639
Old member
Andy4639's Avatar
Cool Re: Ls swap radiator
Plan to use the stock 4 row I have now. Later after the money starts coming in again I will change over to the one on E-bay with both hoses on passenger side along with steam port.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-23-2013, 07:27 PM   #8
pete63
Active Member
I am going to run a lt1 radiator with factory ls1 fans. I would of liked to do an aluminum but this is what i have and the fbody fans are pretty common in a lsx swap from what I have read. First swap so learning as I go.
pete63 is offline   Reply With Quote
Old 10-23-2013, 09:11 PM   #9
67Steven
67Steven's Avatar
Just stay away from R-n-D Fab. Didn't fit at all, was missing parts and then charged me $$ just to take it back. A real pain to deal with.
I went with the Entropy radiator and couldn't be happier!
67Steven is offline   Reply With Quote
Old 10-23-2013, 10:17 PM   #10
Mr. 250r
Mr. 250r's Avatar
kept factory 91 suburban one and put the steam line onto a fitting it has on it
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 10-23-2013, 10:46 PM   #11
ivorton74
ivorton74's Avatar
anyone have pics of their rad with the steam port thing fitted?
Old 10-24-2013, 02:25 AM   #12
BigDan3131
BigDan3131's Avatar
I'm going to use either the Summit or Jegs 2 row radiators both are around $230.00. I removed the stock radiator mounts and am getting one where the core is as wide as the opening. Overall width is about 27" X 19"
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-24-2013, 08:09 AM   #13
solidaxel
solidaxel's Avatar
The one I am going to use is the stock 78 tanks and had the three core changed to a high output larger tube and higher fin count. The shop said it will be better than the 3 core they removed. I then had them add a bung above the trans cooler ports for a steam port. He said they work great here n the SW in June !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-22-2013, 10:09 AM   #14
SparkyRnD
SparkyRnD's Avatar
I'll give the full story on this one. We made the radiator and had the mounts in the incorrect spot. We also missed adding the steam port, which we discussed with the customer. Per our company policies we were building them a replacement, but the customer was unhappy and wasn't willing to accept a replacement. We gave them a refund minus shipping. The full product price was refunded, even though that wasn't part of the terms & conditions the customer had agreed to when purchasing.
If you do some searching, you will see that over the last 5+ years, and thousands of radiators sold, that there have been maybe 4 or 5 instances where there were mistakes and / or the customer wasn't satisfied, and in each case, we refunded the purchase price. We strive to make the best product we can, and in a few cases, we fell short of that goal. When we do make mistakes, we make replacements and send to the customer at our expense. It's unfortunate that we weren't able to get Steven a product he was happy with, but we do have a very good reputation and always look for ways to improve. You can also see on this forum that we have satisfied customers and that the radiators do fit properly.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 12-22-2013, 11:31 AM   #15
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I ran my steam port back into the water pump via a drilled and tapped hole. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 12-23-2013, 11:58 AM   #16
Billett
Billett's Avatar
Ran my steam port to water pump also. I used the stock SBC rad for a while, but mine started to leak. Just from age and use, nothing wrong with using them. I just happened to get a good deal on an aluminum from pro performance so that's what I run now. Its a champion 3 row, and I picked it up for just over $200, no fans. I use a late 90s Silverado dual fan setup. Needed a lot of trimming but it was free!
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 12-23-2013, 07:04 PM   #17
ivorton74
ivorton74's Avatar
do u guys have pics of ur rad setups?
Old 12-23-2013, 11:01 PM   #18
TR65
TR65's Avatar
I used a Griffin set up for an LS motor with the correct inlet and outlet size and the steam port bung. These radiators are made in SC. They make all the parts, cores, tanks, fittings. I used one rated for 600 hp so I had to fabricate the upper and lower clamps, just like stock except wider.
These are really nice radiators. You can see the steam line hookup in the first picture. I tried a Champion and the core leaked pretty quickly.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 12-24-2013, 12:12 AM   #19
stevenbear72
stevenbear72's Avatar
I'm most likely going with the Rnd radiator and shroud, Sparky told me I should have no issues with it.
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 12-24-2013, 12:59 AM   #20
67Steven
67Steven's Avatar
I have a record of emails that spell a different story.
I would have been more than happy with a replacement. In fact, I originally did ask for a correct unit for my application, not a refund. I only asked for a refund after waiting 2 weeks for research into the problem, and then being told you were waiting for pictures and were not sure how much longer it would be before actual work on a replacement would begin. I was denied a refund and so I waited some more.
You offered the refund after 'working' on my original unit for 3 weeks and did not know how much longer it would be. From notifying you of the problem to the refund was almost 11 weeks.
Your radiators seem to be of good quality, just the poor customer service that I experienced soured my opinion.
Old 12-24-2013, 01:05 AM   #21
ivorton74
ivorton74's Avatar
if I run the stock sbc how do I route the rad hoses?
Old 12-24-2013, 01:29 AM   #22
Blackpony
Blackpony's Avatar
I just used a factory lower hose for my 85 then used the factory upper from like an 03 5.3 truck. All fits well here with just a little trimming to the hoses to make them fit just right.
Old 12-24-2013, 02:30 AM   #23
ivorton74
ivorton74's Avatar
got any pics of it? I want to know exactly what it supposed to look like
Old 12-24-2013, 10:26 AM   #24
Blackpony
Blackpony's Avatar
Sure no problem. Excuse the ugliness
Here is how the top hose is routed. I will snap a pic of the lower hose in a bit and post it up.
Old 12-24-2013, 11:31 AM   #25
solidaxel
solidaxel's Avatar
What is the little tank next to the alt. used for?
LS 3 4L70E
