12-14-2009, 09:03 PM | #1 |
can a pickup frame be used on a blazer
I seen a 72 blazer this weekend. I have been wanting to convert one to 2wd. I have a long bed frame and thinking it might be easy to shorten it to the length of a blazer. My qusetion is can it be done. Other then shorting it and changing body mounts is everyhting else the same.
Kevin 67 custom cab big window swb 350/700r4 4/6 drop tilt,a/c 69 custom/10 swb 350/350 4/6 drop tach,tilt 71 cheyenne super swb 454/700r4 4/6drop tach,tilt,a/c,bucket seats,speed warning 96 gmc swb |
12-14-2009, 09:06 PM | #2 |
SKINNY TIRES RULE!
Re: can a pickup frame be used on a blazer
If you have a pickup frame and a Blazer frame, it would be easier to swap the 2wd stuff to the Blazer frame. Using a PU frame would require shortening the frame and fabricating body mounts.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
12-14-2009, 09:16 PM | #3 |
This question has come up at least 5 times in the past 2 months!
12-14-2009, 09:30 PM | #4 |
I don't have any details for you, but several years ago a friend of mine shortened shortbox 2wd frame for his blazer. It wasn't very difficult.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
12-14-2009, 10:35 PM | #5 |
what we need is someone who will do one so people will no if it is truly possible and can be done every one on here has a lot of different opinions on if it will work or not but no defendant answers. i would kinda be interested in it also if done right it would look like a factory 2wd.
12-15-2009, 12:12 PM | #6 |
When my friend did his, he shortened the frame by the difference in wheelbase, and added the rear blazer mounts from his blazer frame. I did see it, so I know it can be done and isn't extremely difficult. I'm sure someone on here must have done it as well.
09-14-2018, 03:42 PM | #7 |
I am trying to do the same thing.I have a 71 4x4 jimmy that would be nicer if it was riding smooth and 2wd. I know the frames can be shortened cause I have done a lwb to swb but don’t know if body mounts line up if you shorten a long frame to a jimmy.I don’t want to violate the stock frame in case I feel like making it 4x4 again. I want to be able to just sit the body on and go either way.
09-15-2018, 03:51 AM | #8 | |
That being said, I have a factory 2wd Blazer and before I modified it to my liking, it still rode like crap
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
09-15-2018, 02:54 PM | #9 |
It’s mostly not about the ride quality for me. In 4wd form it dosent ride bad. I just want to have a 2wd and 4wd version. Since I have 2 I might as well. Located a frame now just have to measure and see how body mounts line up.
09-15-2018, 11:16 PM | #10 |
I just scrapped 2 if you need some extra body mounts.
09-18-2018, 06:22 AM | #11 |
My son and I are in the process of doing this exact swap right now, 72 k5 to a 69-72 swb frame. Shortened the frame 11” set the body on everything lines up with the exception of 1 missing mount on each side.
09-18-2018, 06:27 AM | #12 |
My son and I are doing this exact swap at the present time. Shortened a swb frame 11” mounts line up other than 1 that the pick up frame didn’t have. We knocked the rivets off the k5 frame and used those on the new frame. No other issues....so far.
09-18-2018, 05:52 PM | #13 |
I think the 65-72 snub nose P10 is the same as a blazer frame.
09-18-2018, 09:09 PM | #14 |
Where did you cut the frame? Any pics?
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash 1972 SWB C-10 Highlander Blue/White 1972 Canadian 2wd Jimmy light olive 1970 SWB 4x4 4 speed 307 |
09-19-2018, 05:54 AM | #15 |
We cut the frame under what would have been the cab floor behind front cab mounts, I don’t know how to post a pic up on here but if you want to message me I can either email or text you a couple pictures. Was a pretty good job to do. It just takes a little patience which is hard for me lol
09-19-2018, 09:29 AM | #16 |
