09-07-2018, 12:04 AM | #1 |
Engine Temp
What temp would my otherwise stock engine be running if the gauge is straight up and down?
Currently running a 180 t-stat. |
09-07-2018, 12:45 AM | #2 |
Re: Engine Temp
this link is just a reference .A tool like this will let you test that gauge and it's accuracy .https://www.homedepot.com/p/General-...ntal2_rr-_-100
09-07-2018, 06:17 AM | #3 |
Re: Engine Temp
My gauge never goes past 1/4 of the way with a 195 stat.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
09-07-2018, 07:20 AM | #4 |
Re: Engine Temp
The stock gauges are really not good for much. I always run a good temp gauge.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-07-2018, 10:49 AM | #5 |
Re: Engine Temp
09-07-2018, 12:56 PM | #6 |
Re: Engine Temp
Assuming the tstat and cooling system are working properly, the normal op-temp is 10-20* higher then the tstat temp. Tstat temp is when they start to open.
I think some of those laser temp things get confused by the air between the target and the gauge. Don't put too much faith in the accuracy of a 40 year old mass produced gauge. |
