Old 12-07-2018, 06:47 PM   #1
bigmoe
bigmoe's Avatar
79 rearend in a 64?
So I've got a line on a 79 1/2 ton that I plan to scavenge the front suspension, etc., from but I'm tossing around the idea of using the rear end, especially if it has a better ratio. I understand it will be 3/4" wider on each side. I can manage to mount the pads for the trailing arms and maintain the proper pinion angle but what do I do to mount a panhard rod?
bigmoe is offline   Reply With Quote
Old 12-07-2018, 09:23 PM   #2
Mike C
Mike C's Avatar
Re: 79 rearend in a 64?
You would probably have better luck if this was posted in something other than the Blazer/Jimmy board.
Your best bet is to buy the kit with new trailing arm mounts and the new panhard rod mount. Speedway Motors has it for $140 inclunding track bar.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-08-2018, 07:57 AM   #3
bigmoe
bigmoe's Avatar
I was wondering where my post went. Not sure how I ended up here, lol.
