Old 12-09-2018, 04:04 AM   #1
woodwright
Enjoying left field
woodwright's Avatar
Cold weather troubles
Having a weird issue. I have a 2000 Silverado with a 5.3. Just recently moved to SW Montana where it gets pretty cold. The last few mornings it's been around 0°f and my truck won't start. Cranks but won't fire. But in the afternoon once it warms up to 20° or so it starts and runs like nothings wrong. No relevant codes when I scanned it. Any ideas? Could this be a VATS issue?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 12-10-2018, 05:53 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Cold weather troubles
When the Passlock activates it stalls the engine and some kind of message will show up on the instrument cluster.
Have you checked whether your ignition coils have fire? Injectors activating?
Break out your scope and check the crank position sensor and cam position sensor and wiring when it's acting up.
A scope lets you look at voltage changes over time as a waveform from crank and cam position sensors and the like.
I already have a DSO203 for other work and I'm acclimated to it so I use it. Not the best for automotive work but it's what I have.
If you are just buying a scope to do automotive work I'd invest in an automotive scope rather than a generic unit like my DSO203 for around the same price... The generic units have a steeper learning curve. Not that the automotive variety is super simple but it likely has presets to do some common automotive diagnostic tasks that a generic scope would require actual training or experimentation to setup.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-10-2018, 08:23 AM   #3
homemade87
With no codes I would guess the engine is not turning over fast enough in the low temps . What oil weight are you using . May not have the proper oil in it for those temps . Will make the engine turn over slower . The engine has to see a minimum rpm to fire .
Does it sound like the engine dragging slow when cranking ? Battery could be a factor as well at those temps . Or a combo of both .
homemade87 is offline   Reply With Quote
Old 12-10-2018, 11:24 AM   #4
woodwright
Enjoying left field
woodwright's Avatar
It drags a little, but I've had slower starts. Its warmer this week. Probably 35 this morning. It fired right up. I'll check the battery.
Clint
Old 12-10-2018, 11:39 AM   #5
homemade87
I have seen where a battery will have enough current and turn over an engine but the voltage be down and not crank . The lower voltage will affect the low voltage electronics and not fire .
If battery it will be a easy fix . Let us know how it goes
