02-12-2018, 02:57 PM | #1 |
Two Wheel Blazer Build
My brother Jim & I are joining the Blazer Project/Builders - We bought this two wheel drive blazer/parts over the weekend and plan to add rust free firewall/windshield frame, new blazer bedsides & new full front floor to create a new rust free body like "lks dcvn" did (New Woodall Industries full blazer rear floor not pictured but came with purchase). Nice to have the board resources. Between the two of us we hope to afford the build !
02-12-2018, 03:00 PM | #2 |
Re: Two Wheel Blazer Build
Pics
02-12-2018, 03:03 PM | #3 |
more - going with a new LT or LS drivetrain
02-12-2018, 03:44 PM | #4 |
Congrats on the 2 wheel drive find and will be watching the build!!!!
02-14-2018, 10:00 PM | #5 |
Yeah! Subscribed to this one. Congrats to you Mike!
Please reach out if you have questions along the way. You keeping it as the 524 Red (Hugger) Orange? |
02-14-2018, 10:17 PM | #6 |
67-72 parts collector,…
Congrats on finding the real deal, Mike!
02-15-2018, 08:27 AM | #7 |
Tom, Thanks. Thinking about Copper/Med Bronze exterior and Medium Saddle interior. But will probably go back & forth till ready for paint !
02-15-2018, 08:31 AM | #8 |
02-15-2018, 08:32 AM | #9 |
02-15-2018, 10:12 AM | #10 |
Hey Mike,... I wondered if you needed these repair panels.
http://67-72chevytrucks.com/vboard/s...d.php?t=756030 Also Classic Heartbeat makes some hard to find repair panels for the B pillar area of these blazers. Well worth the money.
02-15-2018, 12:47 PM | #11 |
Registered 1971 K5
Looks like a solid start.
02-15-2018, 06:57 PM | #12 |
02-15-2018, 07:05 PM | #13 | |
02-16-2018, 08:29 PM | #14 |
No Blazer floor yet - you will need to modify the truck floor at the rear where it meets the bed floor step up panel.
It will involve cutting off the rear of the panel (where the gas tank would be) and then bending up the rear floor to meet the rear floor. If you have the stock floor you can see how it should look when you get done. Watch the progression as the 'cab' floor meets the step up and the bed floor in the pix below. The last picture is how it should look when you get done. |
02-17-2018, 10:13 AM | #15 | |
02-17-2018, 10:32 AM | #16 |
Carpe manana
Good luck with the build Mike. Pete
02-17-2018, 10:34 AM | #17 |
Look here for anything made for blazers,...
http://www.classicheartbeat.com/69-72_blazer.htm These pieces are worth the money. http://www.classicheartbeat.com/cata...nt%20panel.htm
02-17-2018, 12:01 PM | #18 |
There is 1 set of torsion box end caps (one per side) and then 3 other pieces of metal come together in the B-pillar.
The torsion box end caps tie into the pieces that Keith notes above. I did this work on a previous project back in 2010 when many of the aftermarket sheet metal parts below were not available. The B-pillar stuff is easy to see starting in this post and then a bit more detail when I got the other side here. Parts List for a new blazer solid windshield frame 69-72 Firewall (if needed) Cowl Panel (if needed) outer rockers (2) cab floor (1) - will need tweaked for blazer use or 2wd version blazer bed floor (1) Step Up panel between floor and bed floor (1) Rear Wheel Housings (2) Bedsides (2) tailgate (1) doors (2) Torsion Boxes (2) torsion box end caps (2) B-pillar support parts (2) B-pillar reinforcement parts (2) Blazer Body Mount and Bolt kit (1) Nuts/Bolts - Grade 8 - Fastenal or Tractor Supply Most of the links above are from one spot (Classic Heartbeat) - I have purchased from several vendors (GMS Pauls, Tabco, and several different resources AMD, Goodmark, Apex, etc.) so shop around for price, shipping and customer service that fits your needs. Since much of this stuff is oversize - you may want to consider a shop closer to home to save a bit. Several of the board vendors use the sheet metal they supply so they know about updates to molds, which parts will fit and which ones to avoid. Disclaimer - many, if not all, aftermarket sheet metal parts will need to be tweaked to fit perfect. Nothing I used fit perfectly the first time. Let me know what questions you have along the way Mike. Happy to help in any way that I can. Last edited by lks dcvn; 05-02-2019 at 03:05 AM. |
02-20-2018, 10:27 PM | #19 |
Well Mike, you didn't tell me you started a build thread..... Could have saved yourself a lot of work and just bought mine! But then, it's just a fake....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-21-2018, 05:43 AM | #20 |
Beautiful blazer!^^^
02-21-2018, 09:30 AM | #21 | |
Keith is right, Beautiful Blazer ! Are you doing another blazer next ? |
02-22-2018, 06:00 PM | #22 |
Mike - have a look here CA Blazer tub $1800 - http://67-72chevytrucks.com/vboard/s...d.php?t=757696
02-23-2018, 04:29 PM | #23 |
Oh..... Yeah...... Absolutely....... Because they're super easy to do.... Yeah, yeah that's it, they're super easy and the parts are so easy to find, and inexpensive..... yeah because... because I invented the Blazer, yeah.... and I have about a hundred of them... yeah that's the ticket.....
02-24-2018, 11:27 AM | #24 |
OMG - Tom Vogel steered me to a website called "roadster shop" ! Makes you think real hard about spending twice as much on suspension to get all new. Whoa - really nice stuff.
03-04-2018, 08:09 AM | #25 |
I'm in for this one!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
