Which camshaft?
After some more planning, what I need for my truck to be a daily driver is eating a small budget quickly. I'm putting the vortec heads to the side for now. Honestly will probably sell them and go with better heads in the future. For now I am pulling the engine out, Paint, new gaskets, new external wear parts ( water and fuel pumps,belts, one wire alternator, etc.)
While it's out I'm going to change cams because it's easy to do now. What is the best cam for torque with stock engine? It is a 1972 350 rated at 175 hp from factory. Probably pushing 140 now haha. The ngine build plan for now and the future is strictly torque. Not milage ( that word never applied to these bricks) and not hp. It is a workhorse and torque wins over hp. I am unable to confirm the head numbers til I pull it and deep clean the engine. I would like to have parts in hand before that point. What is your experience? Any go to camshaft for high torque in a stock engine? I plan on getting the cam lifters in a kit so as to match, and I'm upgrading to double roller timing chain. I do have HEI ignition already. I will also be going dual exhaust at this time also. Fuel is supplied by a well built factory quadrajet and it has no plans on leaving anytime soon. I just like it too much. Also if there are any suggestions for a better spring to compliment the cam, I am open to suggestions as long as it fits the budget. You guys have been great help with all my questions. Thanks once again
1972 GMC C20 Custom Camper 350/TH350 |
Re: Which camshaft?
This is the old standby cam for a small chevy. This is the same grind Edelbrock sells for their Performer intake. It should be fine with stock springs. Cam & Lifters less than $100.
https://www.competitionproducts.com/.../#.XFpRMFxKjIU
Re: Which camshaft?
If you were going to have the engine apart for a complete reseal, while you have the intake off, remove each a lifter one at a time and check the lifter base for condition-wear. Make sure and reinstall the lifter in the same hole as you check each one. If all 16 pass in good condition and you had no valvetrain noise before disassembling I wouldn't change the cam, just leave it alone. There's too much risk with junk aftermarket camshafts and lifters + issues with zinclless oils. You can't beat the quality of those original GM components if they are in good condition.
You've mentioned budget-daily driver a couple times, I wouldn't open this can of worms unless it's absolutely necessary. It's not worth the few extra horsepower for the risk. I speak from a lot of experience with this....... Steve weim55 Colorado |
#4 | |
Re: Which camshaft?
hi, 72kool. I,ve had the same cam mentioned above. 204 214 420 442 on a 112. one 350 255hp 9.0 comp. and another 350 crate with 8.0 comp. that cam works great in both. hope this helps, BROWN 70
#6 | |
Re: Which camshaft?
I agree with you on a typical flat tappet engine that has a good cam with proper break-in the zinc additives aren't all that necessary on a typical old mid high mileage V8. The valve springs are so weak with so little seat pressure even today's motor oil's do the job just fine. I've had plenty of customers that have run the newer oil's unknowingly for years with no issues. I won't run any flat tappet engine without a proper zinc oil but that's me. Steve weim55 Colorado Last edited by weim55; 02-06-2019 at 06:03 PM. |
#7 | |
Re: Which camshaft?
The torque increase you are looking for is in those Vortec heads. There isn't a better cylinder head for the $$ for your application. The torque power increase from the camshaft really isn't worth the effort and money. I thought for the future would be a swap for a complete L31 engine. Roller cam and those efficient cylinder heads. A great low-cost package. The only downsides purchase a correct intake manifold and add an electric fuel pump. Steve weim55 Colorado |
#8 | |
![]() Join Date: May 2013
Re: Which camshaft?
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
Re: Which camshaft?
Im on the fence about a cam as well. I want something that will idle with a decent beat, work with a stock converter and pull hard to 4500. I have 202 aluminum heads, headers, and a 355 bottom end.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#10 | |
Re: Which camshaft?
https://www.summitracing.com/int/par...1102/overview/ The engine had decent pull even with the 2.73 the truck had. It didn’t sound crazy but still had a nice sound from what I recall. |
![]() Join Date: Aug 2004
Re: Which camshaft?
Comp 268 High Energy. Works well with a stock stall but you will feel a difference. Fun to drive and pulls, but it isn't hard to live with at all.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
