Old 03-18-2019, 12:18 AM   #1
robbie_d68
New LS Swap, have question on shifter
There is all kinds of information on LS Swaps on this forum and youtube. One thing that I am having trouble finding is how to hook up your old gear shift. How do you use the Neutral safety switch, do you need it? Can I use my old shifter just without the neutral safety switches? Almost done with the build, just trying to get this figured out without having to take it to a trans shop to finish the build.
1972 C10, LWB, 5.3 / LM7, 4L60e
robbie_d68 is offline   Reply With Quote
Old 03-18-2019, 09:22 AM   #2
MDPotter
MDPotter's Avatar
Re: New LS Swap, have question on shifter
If the stock gear shift you're referring to is your stock shift column, then you can use Lokar's shift linkage kit. From what I've read, as long as you have the wiring in the column to serve as the safety switch and and reverse light signal, you don't need it. Those stock switches that mount to the transmission (in the OEM form) serve as gear indicators as well as neutral safety (so vehicle won't start in gear or neutral), reverse light signal, and to tell the PCM what gear the trans is in. But if you've got a stock automatic column, it should have the wiring for the neutral safety and reverse lights. If you get rid of the switch, the engine idle won't change when you shift gears. If you're doing a cam swap, you might consider leaving it as I've heard it can be an issue with idle.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 03-18-2019, 10:02 AM   #3
joeydurango
joeydurango's Avatar
It's been several years, but on my LS swap (since sold) I recall just using the the stock wiring/switch/column shifter, and a Lokar shift rod to reach the 4L60e - pretty much what MDPotter is suggesting above. Nothing complicated. Of course, I could be misremembering, it's been a while...
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
4l60e, hurst, ls swap
