Old 05-25-2019, 09:50 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
ORD steering brace
NOS manual box on added an ORD box brace.
Strange enough the frame wasnt already broken.
Old 05-25-2019, 09:56 PM   #2
sweetk30
sweetk30's Avatar
Re: ORD steering brace
every one of my trucks gets a ord brace kit .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-26-2019, 12:26 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Test drove it after changing the oil.
No more death wobble. 🙃
Old 05-26-2019, 10:57 AM   #4
cadillac_al
How do you overpower the steering box on a 2 wheel drive truck? I have seen C10's take ridiculous abuse and never cracked a frame around the steering box. I can see putting them on 4WD's but I don't get the 2WD's.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-26-2019, 11:18 AM   #5
sweetk30
sweetk30's Avatar
85 2wd of mine was broken when i purchased the roller truck to build up . i had to weld it up and use the plate kit to fix it . even had a crack in the lower rail lip at the first of 3 bolts that holds the crossmember to the frame .
Old 05-26-2019, 12:16 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
My 77 was broke
Brothers 78 was
Our 68 is broke
Was really surprised my 73 wasn't
Old 05-26-2019, 12:39 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Broke nearly off at the front crossmember on the 78
Old 05-28-2019, 12:44 PM   #8
tinydb84
tinydb84's Avatar
I have been thinking about doing this on mine as a precaution. How is the fit and finish?
David
Instagram: myfabguy
Old 05-28-2019, 01:42 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Nicest aftermarket stuff I've installed recently.
Needed a spacer between it and the factory crossmember.
Tightened up the steering considerably, but changed the box the pitman arm and added the brace in one shot.
Old 05-28-2019, 10:17 PM   #10
sweetk30
sweetk30's Avatar
the ones i have installed just the bolt in brace kit and nothing else ..... they are much more firm in the feedback not as spongey . taking out the frame flex in this area does a lot .
