05-31-2019, 04:15 PM | #1 |
Help - Pictures of torsion bars???? Please!!!!
Help - I need pictures of a set of stock torsion bars that are out of the vehicle, laying on the ground side by side. I believe mine are twisted and want to confirm that they should be the same side to side and not twisted in a left/right orientation like i'm dealing with.
Thank you so much!!!!!!!!!!!!!!!! You can see how low the adjusters are in this picture, and thats with 2 1/2" drop spindles.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-03-2019, 11:59 AM | #2 |
Re: Help - Pictures of torsion bars???? Please!!!!
I cant believe nobody has a set of good ones laying around they could take pictures of...
06-03-2019, 12:09 PM | #3 |
Junior Member
I have torsion bars as well, but they are installed. I do not have dropped spindles, and my key bolts appear to sit quite a bit lower than those in your photo. I do have the front suspension "sagged" so to speak, so that is why mine sit so low. Mine are easily the closest item to the ground under my truck.
DP |
06-03-2019, 01:51 PM | #4 | |
When I put mine on the ground side by side they are twisted in a left and right fashion. I wouldn't think they would be a left and right torsion bar. I need pictures of some good ones just laying on the ground...
06-03-2019, 03:51 PM | #5 |
Page 8 on my build
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
06-03-2019, 04:44 PM | #6 |
Yes I saw there. they look twisted too. Both ends don't lay flat.
Thanks man!
06-03-2019, 08:43 PM | #7 |
Don't know if this will help. I had my bars cranked down before I did my drop spindle swap I had to re adjust them post # 4
http://67-72chevytrucks.com/vboard/s...ight=1960+disc
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
06-03-2019, 08:54 PM | #8 |
I looked at my 62 C20 hardware. There is a LH and RH torsion bar. Mine has "878" and an arrow pointing CW cast into the RH side (end near the key). The LH side has "877" and a CCW arrow cast into it. By eyeball measurement, it looks like the "flats" on each end of the bar are aligned.
06-04-2019, 11:45 AM | #9 | |
06-04-2019, 03:53 PM | #10 |
Moderator
I'd either talk with Aspen parts in AZ or place a WTB add in the parts for sale section. I don't think they're available new.
06-04-2019, 05:32 PM | #11 |
It appears with all the people telling me I should have swapped out for a coil spring cross member, there would be plenty laying around...
Ill check out your source.
06-05-2019, 01:49 PM | #12 |
Moderator
Check out today's thread - http://67-72chevytrucks.com/vboard/s...91#post8537391
06-05-2019, 02:45 PM | #13 |
06-05-2019, 04:01 PM | #14 |
Moderator
This will get shut down if it turns into a WTB thread - Just sayin.
06-05-2019, 05:11 PM | #15 |
I need to know if mine are messed up before that happens, that's the who point of this thread, to confirm mine are good or bad.
06-05-2019, 11:29 PM | #16 |
Maybe a stupid question.... is your main concern with how low the adjuster bolts hang, or are you having a ride issue?
06-06-2019, 12:15 PM | #17 | |
When I got the truck, the shocks were fully compressed and it rode like crap. I went through the front end new shaft ball joints, steering, added PS, drop spindles, disks. went to take off jack stands (didn't put shocks back in) truck laid out the cross member on the driveway. Tires crammed against the top of the wheel wells (I guess the shocks were the bump stops...). Tried rotating torsion but couldn't get ball joint back on - I was screwed. No way to change ride height. So I pulled both bars. They were twisted about a half a turn on each side in a left and right fashion. I swapped them side to side and this is where I am. From your pictures and judging by the center of the dust cap, Im riding higher that you were when you put the spindles on (before adjusting), but my adjusters are lower. My thoughts are, since every other part and system on this truck was hacked and half assed by the PO, it wouldn't surprise me if the dude use a torch and heated up the torsions to lower it. I just got lucky that i could swap side to side and get it driveable. I just need pictures of the ends of a good set laying side by side and that will answer my questions.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC Last edited by demian5; 06-06-2019 at 12:32 PM. Reason: Adding image |
06-06-2019, 12:40 PM | #18 |
I wonder if they are actually different between half and 3/4??
06-06-2019, 08:26 PM | #19 |
Old post .... but maybe the pics will help
http://67-72chevytrucks.com/vboard/s...hlight=TORSION
06-06-2019, 08:27 PM | #20 |
06-07-2019, 10:47 AM | #21 | |
06-07-2019, 10:52 AM | #22 |
Yeah Id love to try those bars and see if they make a difference.
06-07-2019, 12:28 PM | #23 |
For what its worth.....the shop manual states right and left are different
06-08-2019, 01:00 PM | #24 |
Bars long gone, Al at Tuckers in LV has/had. You might give them a call. Tom might have some stashed.
https://www.tuckersparts.com/
