10-02-2019, 08:24 PM | #1 |
Backing up with a tow bar
When I remove the engine from my truck, I would like to roll the truck out of the garage and power wash the engine bay. I have a list of things I want to do with the engine and the engine bay while the engine is out.
When it comes time to put the truck back into the garage, which is uphill, I was thinking of putting this tow bar on it and use my SUV to back the truck into the garage. I understand these trucks track fine when going forward. Should I expect it to be a different story and big trouble to back it up? It is a 1969 CST/10 pickup with power steering and manual brakes. |
10-02-2019, 08:37 PM | #2 |
Re: Backing up with a tow bar
I don't know; I don't think I've ever backed up with a tow bar.
I don't think it will be too bad since it's just a one-shot deal. I imagine you will be going slow; you would be able to stop and straighten it up with the floor jack or by steering the wheels of the towed vehicle. I have a lag bolt in the post in front of my repair stall. That allows me to pull any disabled vehicle up in the garage with the come along. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-03-2019 at 06:54 AM. |
10-02-2019, 08:53 PM | #3 |
I did that with mine. Not to bad as long as it is going straight back. Helps if you have a second person steering the truck while you are backing up.
10-02-2019, 09:05 PM | #4 |
Might tie up steering wheel like the wrecker guys do if you by yourself.
10-02-2019, 10:05 PM | #5 |
I would have someone behind the steering wheel making sure it tracks.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-02-2019, 10:36 PM | #6 |
Who Changed This?
Either of the last two replies are great, if you don't have someone to help. Backing with a tow bar (or even towing forward when turning sharp corners) has to be done carefully.
10-02-2019, 10:54 PM | #7 |
Are there any special considerations or problems I could have with unpowered power steering?
10-02-2019, 11:32 PM | #8 |
It shouldn't be a problem with the steering. As said earlier, you will need someone behind the wheel or tie the wheel down. I tow a Jeep behind our motorhome and if I back up far I have to do one of the above.
10-03-2019, 12:27 AM | #9 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
It should work quite well because the tow bar is a solid connection allowing the push vehicle to become an extension of the non-motor vehicle. I'm doing the same maneuver with one of my 72's but instead of a truck with a tow bar I use a Ford 8N tractor with a 3-point boom. I have also used a snatch block anchored to the shop floor and use a winch. A positive connection on a sloped or inclined surface is probably the safest way to move that truck. If you don't have a co-pilot to help steer, a couple of ratchet straps will hold the wheel. Tow bar should work and work well, just take it slow and easy...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
10-03-2019, 02:18 AM | #10 |
The shorter the wheelbase on your tow rig the better in this situation. I've backed up cars on tow dollies with my S10 Blazer. I would not even attempt it with my Burban.
One other note if you have power steering you need to loop the hoses or make other provisions to catch the fluid.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Tags |
tow bar |
