01-04-2018, 09:52 AM | #1 |
Help, High idle problem TBI, how the heck do you get it down.
I have a 1988 Chevrolet V30, 7.4, 400 transmission. I have a high idle problem. On startup it’s idles way to high and never really drops down. Truck has low original miles on it. Changed...iac, tps, rebuilt TBI and new base gasket, pulled the egr and it’s not froze up, new fuel pump. Never touched the timing, could timing cause it on a TBI ? Sorry for the stupid question but I’m not a technician, just a parts changer...
01-04-2018, 09:58 AM | #2 |
Re: Help, High idle problem TBI, how the heck do you get it down.
One of mine idled high, I turned the idle screw out some. But for whatever reason they have a plug that covers up the screw. I think there is a way to “reset” the IAC and TPS but not 100% if that adjusts idle speed or not.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-04-2018, 05:30 PM | #3 |
Coolant temp sensor will make it idle high too.
On the front of the intake. Our 92 454 rib would idle way high and that solved it |
01-04-2018, 08:14 PM | #4 |
Did you replace the gasket under the adapter plate?
01-04-2018, 08:20 PM | #5 |
check all the vacuum lines for cracking...high idle is usually a vacuum leak....
also as someone stated check the coolant temp sensor AND the connector.... but usually if either one is bad you will get a rich condition in addition to a high idle...if the pcm sees a cold engine condition it will dump in extra fuel.... also check the IAC for proper operation....this controls the amount of air going in at idle... and check the TPS voltage at idle...you may need to tweak it a little. read here...http://www.gmtuners.com/tech/TPS_IAC.htm
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
01-05-2018, 04:48 AM | #6 |
01-05-2018, 04:50 AM | #7 | |
Good reading on the link, thanks. |
01-05-2018, 03:52 PM | #8 |
If you rebuilt it, follow the steps for the minimum idle setting.
Also, get a ALDL cable and download a scanning app and you won't need to guess about whether sensors are good.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
01-06-2018, 10:31 AM | #9 |
Thanks for the info, I certainly need the ALDL set up but I ditched all my PC stuff and drank the apple coolaide
01-06-2018, 07:52 PM | #10 |
Where the heck is the coolant temp sensor anyway ?
01-06-2018, 10:35 PM | #11 |
I said on our 92 it’s right by the thermostat front of the intake not sure if 88 is the same know it’s a different manifold
02-06-2018, 08:14 PM | #12 |
So I finally had a chance to get back to working on the truck. Ordered the coolant temp sensor and it was the wrong one, mine is a 2 wire and I got a single wire. I ordered the right one and it should be here in a few days. Until it arrives I took the IAC off and started the truck and it shot up to 3000 Rpm’s or higher. I wanted to plug the big hole ( where IAC is) to see how it affected the idle but the idle was too darn high so I turned it right off. I read where if you plug that hole it should barely idle.
“With the IAC passage completely plugged the engine should barely be able to idle, fully warmed up with all accessories off. If it still idles fast with the IAC passage plugged there is a vacuum leak somewhere. Extra air getting in the engine will speed up the idle. Check all the vacuum hoses.” I used carb cleaner all around the vacuume lines and base gasket before removing the IAC and no change in the...to high of an idle. Dang I’m frustrated |
02-07-2018, 12:19 PM | #13 | |
This is part of the IAC reset procedure in the link posted above: 1) With the IAC valve connected, ground the diagnostic (ALDL) terminal (same as you would do to flash trouble codes thru the check engine light). 2) Turn ON the ignition, but do NOT start the engine. Wait at least 30 seconds. 3) With the ignition still on, disconnect the IAC electrical connector. If you stop right here, you should be able to look into the IAC passage on the top of the throttle body and see the end of the IAC pintle as this procedure drives the IAC fully closed. If you can't see the end of the pintle, you've probably found the source of your high idle as the IAC is not fully closing and cannot control your idle. |
02-07-2018, 09:15 PM | #14 |
Thank you, I may just head back over to the shop and do this procedure.
02-08-2018, 03:08 PM | #15 | |
Thanks! Would it hurt anything to drive it with the IAC unplugged ? Last edited by 57NAPCO; 02-08-2018 at 04:17 PM. |
02-09-2018, 04:00 PM | #16 |
Did you do the minimum idle setting yet? You are just chasing your tail if you didn't start there.
02-10-2018, 10:37 AM | #17 | |
Thanks for the tip. ...I’m trying figure out what changed to make the idle go too high. Ran and started fine for a few years. Thanks again for all the help y’all! Last edited by 57NAPCO; 02-10-2018 at 10:43 AM. |
02-10-2018, 12:09 PM | #18 |
Active Member
I read through the posts but I may have missed this: Did the truck just all of a sudden start idling fast or was there some work or parts replacement done that caused it to idle fast?
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
02-10-2018, 02:13 PM | #19 |
It just started one day, I did drop the tank and replace a faulty fuel pump.
Been driving it for a coupe days now with the IAC unplugged and it runs great starts fine and idles right. The IAC is new, A/C delco part. |
02-10-2018, 04:10 PM | #20 |
Active Member
If it's running fine with it unplugged there's bound to be a leak somewhere. Is it possible that a vacuum line from the tank may have broken or come unplugged? http://repairguide.autozone.com/znet...528005c9bd.gif
It could also be the intake manifold gasket or other place where air may be getting in. The problem with running with it disconnected is that when starting or when engine is cold it may have trouble idling properly -sometimes when coming to a stop. There is a possibility that the IAC is new defective. These days even OEM parts are not super reliable. I can't begin to count the new parts I've returned in the past for being defective.
02-10-2018, 04:58 PM | #21 |
Thanks!
02-11-2018, 01:54 AM | #22 | |
1. IAC--did you make sure you removed all the old gasket material/replace the IAC gasket when you changed this? That is a potential vacuum leak. Also, did you have the idle problem before you changed the IAC? 2. TPS--did this affect your idle in any way? Unless defective, it shouldn't. 3. Rebuilt TBI--Did you rebuild your throttle body or install a rebuilt unit? The BBC's had two different base footprints over the years. If the base footprint of your throttle body doesn't match the gasket you used and the mounting surface on the intake manifold that could cause a big vacuum leak. 4. Pulled the EGR--Did you replace the gasket when you reinstalled? 5. Have you tried capping off each vacuum tap from the throttle body/intake manifold one by one? If you have a leak in one of the lines, doing this will help you find it because with the IAC unplugged as you have it now you would cut off the air and the engine should almost stall.
1988 Chevrolet C1500 RCSB |
02-11-2018, 07:02 AM | #23 | |
Gonna get this feller sorted out, one way or another
02-12-2018, 12:44 PM | #24 |
Hello When I did the head gaskets I cleaned and rebuilt the TBI and replaced with new gasket. Now years later doing the intake manifold gaskets I found that the TBI bolts were loose. I wondered why the engine would surge. That probably was the problem. So now after I get the intake squared away I will always check the TBI bolts.
02-12-2018, 02:43 PM | #25 | |
http://forum.73-87chevytrucks.com/sm...?topic=21039.0
