Old 09-22-2007, 10:32 PM   #1
Chevy Fleetside
Chevy Fleetside's Avatar
Big Block Build is what I'm calling mine. New pics inside
I got the Headers Thursday and tried fitting them tonight. Seems for me to get the left one in I will have to take the plugs out and I have to cut the frame a little for more clearance on the right side as you can see in this picture. They will bolt up but 1/16 of an inch clearance from the frame is not enough. I still have to patch the firewall on the left side also...
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-22-2007, 10:33 PM   #2
Chevy Fleetside
Re: Big Block Build is what I'm calling mine. New pics inside
forgot the pics...
Old 09-22-2007, 11:35 PM   #3
Chevy Fleetside
Just so all of you know. The big block will be painted like this..
Old 09-27-2007, 09:24 PM   #4
Chevy Fleetside
Damn,,, Tough crowd....
Old 09-27-2007, 11:27 PM   #5
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Looking good. I did notice the clearance between distributor and fire wall. Have you put the cap on it yet?
I wish I was that far along.
Good Luck
Alan's Classic is offline   Reply With Quote
Old 09-28-2007, 01:10 AM   #6
65chevypickupguy
65chevypickupguy's Avatar
Instead of beating on the firewall, unbolt the frame mounts, slide everything forward just enough to clear distributor, valve covers, etc, Then scribe the holes on the frame mounts and drill new holes. I assume you're using a newer transmission and you're going to have to make a custom drive shaft? I had to do it on my small block with HEI.
65chevypickupguy is offline   Reply With Quote
Old 09-28-2007, 04:15 AM   #7
63 & 64 Bowties
and a few others
I really like the engine color. did you have it that color already, then tear it down, 'cause that don't look like a photoshop paint job.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 09-28-2007, 09:34 AM   #8
Chevy Fleetside
I am putting the engine in the stock location. I am putting a built 700R4 and I already have the shaft for it. If I move the engine forward I will have to have another shaft made up. There is plenty of clearance for the dist cap to fit in there seeing it is the smaller HEI.
That was the first paint job. I really didn't like the way it turned out. It looks much better in pictures then in person. That was also my first paint job and I have learned alot more now. I did rebuild the truck once and drove it for 4 years and started to develope rot under the left door and there is a big scratch down the right door, so I decieded to upgrade. I still have the engine that is all painted blue plus another one so I am not short of small blocks, and they are both TBI engines.
I also switched from a stepside bed back to a fleetside. I really wanted a fleetside in that year and maybe I will pick up another stepside again after I am done with this one.
Old 09-29-2007, 12:35 AM   #9
Iron-Butt
454 club
Iron-Butt's Avatar
I had to cut the frame on both side when I put the 454 in my 65. I used the stock exhaust manifolds.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 09-29-2007, 01:01 AM   #10
Captainfab
60-66 Nut
I had to notch the frame for the #2 tube on my '66 Suburban also, in spite of the fact that I moved the engine forward ~2"
Old 10-10-2007, 10:14 AM   #11
Chevy Fleetside
With the engine in the stock position I will just have to take a nib from the frame for the front tube on the right side. I haven't fitted the left side yet..
Old 10-22-2007, 06:05 AM   #12
Silver
Please tell what headers were used to fit. I to have replased my small block with a 454 and need help with the headeds.
Silver is offline   Reply With Quote
Old 10-22-2007, 09:38 AM   #13
Chevy Fleetside
They are Hedman Elete Headers for a chevy truck.. My engine is sitting back with the stock mounts so the headers clear the frame better but still need some grinding on the frame so they don't touch.. With the engine mounted up a few inches I think you have to cut the frame more but not 100% sure of this. Other had to cut the frame for the headers. On the newer trucks the frames up were the headers are, are much narrower then in the 60's trucks..
Old 10-22-2007, 10:02 AM   #14
jchav62
1962 C-10
jchav62's Avatar
Looks awesome. Can't wait to see the engine painted up....Keep us posted...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-22-2007, 03:14 PM   #15
Silver
What year truck, I hate to keep after this but I have already tried two differant styles. I know that 66's did not come with big blocks, so what yaer should I be looking into.
Old 10-22-2007, 07:57 PM   #16
Ronin8451
Ronin8451's Avatar
I used cheap headman headers for a 67-72 on my old '66 with the 427 in it using stock motor mounts and dimpled one tube ( can't remember which one) and the frame already was notched by the PO for the first tubes on each bank. I never found any that would just drop right in .
1970 SS El Camino Resto-rod
1951 Chevy 3100 ( in pieces at the moment)
1964 C-10 Long Step ( new daily play truck)
1999 SS Camaro & 1994 BMW 740IL Daily drivers
1969 SS Chevelle ( next in the resto line)
Ronin8451 is offline   Reply With Quote
Old 10-22-2007, 09:35 PM   #17
Chevy Fleetside
They are for 73-87 year trucks. Also they are 1 3/4 primary tubes and not the 2" tube.
I can't want to see it all painted up too.. also running with me gassing it...
Old 11-06-2007, 10:07 AM   #18
Chevy Fleetside
http://store.summitracing.com/partde...5&autoview=sku These are the headers I used..
Old 12-04-2007, 10:59 PM   #19
NF65Fleetside
NF65Fleetside's Avatar
I made the plunge and got a 454 today also! Have to clean her up a bit and going to get a few small hop up parts. Wanted to know if you guys think that a set of shorty headers would help with clearance issue? Also I have a 65' C10 so will using the stock small block mounts and location be ok? I see that most of you are doing a lot of mods but all for different reasons...just want to know a straight forward way of getting the motor in.
NF65Fleetside is offline   Reply With Quote
Old 12-05-2007, 10:11 AM   #20
Chevy Fleetside
I might as well keep my pictures here... I'm hoping the next pictures I post will be on the engine all nice and pretty,....
Old 06-06-2008, 10:48 PM   #21
Chevy Fleetside
Got the crossmember drilled and mounted today. The engine is set and now I can move on to the next thing.. Now I just have to figure out what that is going to be.. I think I will mount the TBI unit and run the throttle set up..
Old 06-06-2008, 11:00 PM   #22
joe231
joe231's Avatar
sweet
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-06-2008, 11:44 PM   #23
scotts62
One day...
scotts62's Avatar
Cool looks good man
Scott
93 crew cab build
Project 62
Old 06-07-2008, 10:58 AM   #24
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Well it's about time we see some progress !!!
JK man...I know your busy....
Looking good....
You running a stock TBI, or an aftermarket one ?
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 06-07-2008, 03:20 PM   #25
Chevy Fleetside
stock for now. I am not building a hot rod just a cruiser..
