11-20-2019, 01:42 PM | #1 |
Help! Overwhelmed on Where to Start
My first post on the board although I've already learned so much from the collective knowledge here. I recently purchased a number matching 1969 K20 to be my daily driver (I work from home so don't drive much) but also my project car. I even have the original protect-o-plate and original manual/warranty guide that came with the truck.
I was originally looking to do a resto-mod, but the numbers matching thing kinda bothers me. Hagerty's "definitive buyers guide" seems to indicate no one really cares about numbers matching value-wise. I have to keep this as my daily driver for a while before I can do the frame off resto I want to do - but I've got time to do some labor-intensive work to start making it beautiful. Looking for feedback on:
11-20-2019, 02:09 PM | #2 |
Re: Help! Overwhelmed on Where to Start
What do you mean by ‘numbers matching’?
I you mean motor is original then you only have the casting code or the suffix code to go by. Your truck’s motor didn’t have a partial vin on it that matches the truck serial number. Could have a different motor in it. Good looking truck and welcome to the forum. |
11-20-2019, 02:11 PM | #3 |
Make it run, make it stop, drive the heck out of it.
Some weekend projects could be a CLR bath. If your handy with a table saw, make your own wood bed. Small one day successes would keep you engaged in the project too. Sandblast and paint the front bumper for example. Polish the grill, degrease the pumpkin, transfer case, engine. A nice quick upgrade would be a HEI distributor. Just a few ideas to get you learning and enjoying your truck. |
11-20-2019, 02:21 PM | #4 |
Welcome aboard!
The best place to start in my book is to change all the fluids, engine, transmission, axle, and brake. While you are doing that take time to look closely at the truck and note what things look like they need attention. Wiring has a tendency to take a lot of abuse from owners over time so note any non-factory looking alterations. I like to replace alternators/regulators, belts and water pumps on new rigs as they are cheap and will strand you when they fail. There are various nooks and crannies that collect dirt and debris that should be cleaned out. I like to clean then coat with POR -15 to stop or at least slow the rust. It looks like you have a nice unmolested truck. Congratulations! Looking forward to seeing more about it.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-20-2019, 02:24 PM | #5 | |
In my opinion means matching number that the number on your engine block is the same as on your protect-o-plate and your build sheet (under the seat). In my sample VO426GYV V = Engine Assembly plant Flint 04 = month of assembly 24 = day of assembly YV = 327 8cyl w/ 3sp Autom. Trans 4BBL Carb
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 |
11-20-2019, 04:24 PM | #6 |
I would do as others have said and check all the wear items like belts,hoses,brakes,fuel lines,tires,fluids,tune up. Then start on annoying stuff like,Do all the lights work? Does the truck need an alignment? Which entails does the front end need a rebuild. Then chase the leaks.After that you can start the fun stuff but your truck will be drive able and a joy.
68' with no bells or whistles unless I add'em. |
11-20-2019, 05:09 PM | #7 |
Don't sweat numbers matching. They didn't number match trucks. You could verify a truck has the right size motor, but you could never verify that the motor in it was original to THAT truck.
Others have laid out good advice. Focus on the basics to make it safe and reliable first. Make it stop like you really want. Then make it handle like you really want. Then make it accelerate like you really want. And somewhere in there decide how comfortable you want to make it while doing all three of the above. |
11-20-2019, 08:00 PM | #8 |
I wouldn't waste any time or money on making it "numbers matching". Like others have said, make it safe, make it run well, then start working on things like cleaning up the paint, repainting small items, fixing rust, etc.
Unless you can do without it being out of commission for a year or two, I would hold off on doing any restomod work. There's a lot to be appreciated for a nice patina truck like that. You could put in the bed wood, repaint the bumpers, CLR it, redo the seat, install new carpet, give it a tune up, and replace front end parts and do a disc brake conversion and drive it for awhile. Then when you're ready to tear it apart, look at a new powertrain and taking the truck apart.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
11-20-2019, 08:06 PM | #9 | ||
"I ain't nobody, dork."
There were no special engine packages or any kind of numbers on the engines to bring any more value to these trucks. Just sentimental value that it might have the same block in it.
Nice rig and welcome aboard! Gary
11-20-2019, 09:59 PM | #10 |
All about them K’s
That’s an awesome K20! Welcome to the club!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-20-2019, 10:37 PM | #11 |
Man I understand where you are as I just got my truck back in may of this year. Got it running and moving under it’s own power first. Pulled the bed and am now working on rear frame section, rear diff, and brakes. My plan is to have all new bushings, brakes, springs, bearings, etc done by spring. Then I’ll move on to the front where it will be a total rebuild and power steering disc brake conversion. At that point it will be road worthy so I’ll decide what to do with the tired 283. Rebuild or replace? Don’t know just yet. Got a line on a 327 but am holding off until I get to that point. If I look at the whole project I get overwhelmed so I focus on what I’m doing now while planning what’s next.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
11-20-2019, 11:23 PM | #12 |
Sounds like you have got plenty of good advise here. You came to the right place!!
Welcome to the site. Looks like you have a great starting point with minimal rust.
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
11-20-2019, 11:28 PM | #13 |
Thank you for all of the advice! Here is the protect-o-plate, which comes out to:
V1111WO - Flint Engine Plant, Nov 11th, 350c/I 4bbl, 255HP N9R29 - Munchie 4 Speed, 1969, October 29th ND1023G - Rear Axle - 4.57, October 23rd, Chevrolet Gear and Axle Rochester 4bbl Quadra-Jet Carb (this has been replaced with an Edelbrock Carb) Built-in November 1968 This all matches what is on the truck, and I'm the third owner (the second owner was the son of the first owner) so based on what I was told and can verify everything, for the most part, is original. |
11-21-2019, 01:43 AM | #14 | |
Hence why true numbers matching was a big deal, because the VIN on the car matched the VIN stamp on the engine. You can't go wrong with any direction you choose honestly. Do what you think you'll enjoy working on and driving the most. People who worry about the value are the same that keep their cars locked up in a garage and rarely enjoy them . |
11-21-2019, 08:26 AM | #15 |
Haggerty is wrong. It's not true for all vehicles. A well optioned K/20 as it came from the factory is highly sought after and people are willing to pay for that. You can take a commonly available 73-87 3/4t 4wd chassis and 'create' dozens of 67-72 "looking" K/20s any way you want. You can swap a 67-72 C-model body onto a 67-72 K-model chassis but from what I have seen you won't get as much for either with the wrong VIN. There may be more and more fools with more money than sense buying into these trucks every day making foolish moves someone who knows these trucks wouldn't do. I guess it could control where the values/buying preferences go with so much more of that going on, but the true collector knows the most value is in that which can not be replicated, that which has remained as built through all the years. If someone pays crazy high-dollar money for a K/20 restomod it's because they wanted all that modern crap, not a real K/20. Also, to a true enthusiast the money is not what it's about. That is for the investors.
11-21-2019, 10:27 AM | #16 | |
OP: great truck, I wouldn't change too much to be honest. Get some bedwood. Aside from changing all your fluids, start going through your suspension and steering and brakes. People treated them like trucks back in the day, and even beloved family heirlooms take a little abuse. After that, I would personally work on the interior and make it more comfortable. Get a correct radio for it, replace the cracked dashpad, those little things are inexpensive and make the truck more fun to drive.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
11-21-2019, 11:18 AM | #17 |
They are an insurance company trying to be more. They just need to be a good insurance company and that will keep me with them.
11-22-2019, 10:45 AM | #18 | |
And keep it driving as much as possible by doing things a bit at a time. It's harder to be motivated on something that just sits. Nice truck, looks like a solid start. And don't get too hung up on originality; it's not a split window stingray, just a pickup. You could just throw in a piece of heavy plywood for a temporary bed floor. And I'd avoid driving it when the mag chloride is on the roads (wet). It doesn't beat up new cars too bad, but it will definitely hurt the old stuff. Also, welcome from just up the highway.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
11-22-2019, 11:33 AM | #19 |
When I was 17 I focused on these three wise bits of advice in the exact OPPOSITE order! I still find it quite amazing I've made it this far.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
11-22-2019, 12:01 PM | #20 | |
That's when I did my first disc brake swap. Guess that was about 1989 when I had turned about 20. Sense started kicking in.
