07-02-2019, 11:24 PM | #1 |
Just when you think your out (64 FS) 66 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=789027 . . . Just when you think your out (64 FS) 66 FleetSide . Part II . After listening to members about my "66"/ 02 swap I have decieded to go with Option 2: . Just picked up this 91 Sportsvan "Custom" with 60'000 miles on it For the 5.7 and 700R4 and bits to go into the 1966 Fleetside . . . . . . I'll keep you posted Thanks for the feedback....Sp . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
07-03-2019, 10:06 PM | #2 |
Re: Just when you think your out (64 FS) 66 Fleetside
Thanks Mike
07-31-2019, 11:07 PM | #3 |
Big day
Pumped up the tire Last Ride /Burnout on the sportsvan . . . pulled up to the shop . . Nast bit of work It's out . . . . .. .....Sp . .
08-07-2019, 03:24 PM | #4 |
64-66 CHEVY JUNKIE
Hahahaha, For some reason I just thought about Smokey and the Bandit..."Sombit$h" lol
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
08-07-2019, 10:50 PM | #5 | |
Not what I was going for ...But now I see it Good one Rust in piece Buford T justic.......Sp . . / . . .
10-20-2019, 03:19 PM | #6 |
http://67-72chevytrucks.com/vboard/s...d.php?t=795140 . Thanks to hatzie . Manual for 1991 G-30 5.7/4L80E . http://67-72chevytrucks.com/vboard/s...d.php?t=700011 . The Electrical Diagrams (1991 ST-375-91-EDD GM KC Light Trick Wiring Manual) . . ...Sp .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 Last edited by Softpatch; 10-20-2019 at 03:55 PM. |
10-20-2019, 03:49 PM | #7 |
Update
. Drive line in . . Gas tnk mock up 10-17-19 . . In and Running 10-18-19 Wiring Phase . . .....Sp .
10-20-2019, 03:55 PM | #8 |
Do you have another method of hosting images other than Photobucket? I'd love to see your work. Photobucket is kicking me in the eyes right now.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
10-20-2019, 04:00 PM | #9 | |
.....Any recomendations ..?? . My "work" is messy My goal is to piece together these two trucks and make it "Low budget build"
10-20-2019, 04:09 PM | #10 |
Test
10-20-2019, 04:10 PM | #11 |
Test 2
10-20-2019, 06:33 PM | #12 |
That works awesome! Thanks!
11-15-2019, 11:41 AM | #13 |
Temp fab motor mount ( looking back underneath )
Driver side ... passenger side My only issue I believe the Engine angle not right.? I will revisit this after I check off more goals On the truck .......... next mounting ECM Continue Fab exhaust Shift linkages Another Restart .......Sp [attach] [/attach]
11-16-2019, 12:00 AM | #14 |
60-66 Nut
I don't understand why you aren't just using the original engine mount brackets as they are? Any small block will just drop in place with them.
11-16-2019, 11:39 PM | #15 |
The Last owner had a 454 in the truck and it looks like they Modified The Old six cylinder Mounts to fit the BBC .
Those mount I modified were the Mount that were in the truck when I rescued it. (yard art) sitting under Pine tree's 10 + yrs didn't do it any good. They didn't quite fit the 454 because they sat High (6 cylinder).? those mount that came with the truck were chopped on the top of the mount because they look like they needed clearance (hitting both Bottom side of the Exhaust manifold) and The engine sat back so for They beat on the Firewall to clear the Back of the Valve covers on both side for the BBC . so to "Make do" temporary modifie to bring down the saddle part were the mount bolt through till i can sort out the FI I'm still not 100% sure I'm going to use this Motor/Trans set up . My plan for this truck give it some much needed love Make it Running driving truck on a low budget ..... I'm getting really close . ......Sp . . .
11-17-2019, 12:34 AM | #16 |
60-66 Nut
In the '63-'66 trucks, the 230/250 I6 and 283,327 small block engine mounting brackets are exactly the same and bolt into the same location. If you picked up a set of original brackets, your engine would drop right into place, no messing around.
11-26-2019, 12:25 AM | #17 |
today was a big day I have Achieved I milestone....
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 Last edited by Softpatch; 11-26-2019 at 12:42 AM. |
11-26-2019, 12:41 AM | #18 |
Don't know how it happen but .....
Started and Moved out of the garage . . . ................Sp . . .
