Old 10-10-2018, 01:38 AM   #1
AntiqueAtHeart
1965 C10 factory exhaust
Hey fellas, how are you yall tonight?
So I bought a pretty much all original '65 C10 283ci long bed a while back and have been working on the exhaust. Since the truck is fairly original, I want to try to keep it that way exhaust included. When I drove the truck home, I noticed quite a few exhaust leaks and it turned out to be both the "y" pipe and extension pipe were rusted out. Unfortunately, both pipes can't be saved because they were both too thin. I've replaced the "y" pipe with Walker part #42087 which was a perfect fit. The only problem is finding a new replacement for the extension pipe. The only extension pipe I can find is Walker #48111 which is for a L6 engine and not a v8 like the truck has. My truck came with a 2 inch "y" pipe and extension pipe.
Do any of you know where to get an extension pipe for a v8 long bed truck? Unfortunately, the cheapest quote that I got from an exhaust guy was $225....just for the extension pipe. I can't seem to find one. Any help would be appreciated.
-Cam
AntiqueAtHeart is offline   Reply With Quote
Old 10-10-2018, 06:42 AM   #2
Clyde65
Clyde65's Avatar
Re: 1965 C10 factory exhaust
Hello neighbor and welcome to the forum!
I can’t help you but wanted to say hello!
Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-11-2018, 09:27 AM   #3
LT1 Burb
LT1 Burb's Avatar
-Cam
There is a place on Ebay selling complete exhausts from Y pipe back, I used there's on my truck.
LT1 Burb is offline   Reply With Quote
Old 10-11-2018, 07:38 PM   #4
jayoldschool
Moderator
Last time I looked, the Walker over the axle pipe is OOS. They will make more eventually.
jayoldschool is offline   Reply With Quote
Old 10-12-2018, 03:35 AM   #5
AntiqueAtHeart
Thank you for all of your replies. LT1 Burb, do you remember which vendor you bought from? I searched ebay for the said kit and again, all I found were kits for the L6 trucks. I may just have to buy the L6 expansion pipe and modify it myself.
Thanks again for replying.
-Cam
Old 10-12-2018, 09:11 AM   #6
LT1 Burb
LT1 Burb's Avatar
I think it was this guy, he will prolly make you one if you ask.
https://www.ebay.com/itm/1963-1966-C...zz~X:rk:5:pf:0
Old 10-14-2018, 02:06 PM   #7
AntiqueAtHeart
Well, unfortunately no reply from the eBay exhaust guy LT1Burb. Thank you all for your posts. Do yall think if I bought the L6 version of the expansion pipe, that I could modify it and make it work? Is the L6 manifold flange the same as the "y" pipe flange? I can get the L6 pipe all day long. Please let me know.
-Cam
Old 10-15-2018, 09:25 AM   #8
LT1 Burb
LT1 Burb's Avatar
I guess you could check, donut size will determine pipe size so maybe hit up local parts store and check to see if they are the same.
Old 10-30-2018, 11:36 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Have you made any progress?
I need to find something from the y-pipe back for my 66.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-31-2018, 12:30 AM   #10
AntiqueAtHeart
Thank you guys for all your replies. Sadly the eBay exhaust guy that Lt1Burb referred me to has stopped returning my emails so my hunt continues.
LostMy65: My search has revealed that Walker no longer makes the extension pipe for the V8 trucks.....they only make the pipes for the L6 trucks.....makes sense to me.... So, at the moment, the only thing I can think of to do is to shop around some more at the local exhaust shops and go from there. Ill keep this thread going with updates if I find anymore info.
Another question for you guys......Would any of you have a set of stock GM manifolds for a 283 truck? I read that the 327 trucks had a 2 1/2" flange while the 283's has the 2" flange like the ones I have. Mine are cracked and leaking badly. Please let me know what y'all have and throw some prices at me.
Thanks for your time.
-Cam
Old 10-31-2018, 08:52 AM   #11
LostMy65
LostMy65's Avatar
You can buy new.
Among others, Dorman makes them for both 2.5 & 2
Old 11-27-2019, 11:02 AM   #12
1966burb
1966burb's Avatar
I am looking at putting stock single exhaust back on my 66 burb. I have been in contact with WALDRON'S EXHAUST 800-503-9428 or Waldron@waldronexhaust.com
j
1966burb is offline   Reply With Quote
Old 11-27-2019, 11:38 AM   #13
vince1
https://www.grammar-monster.com/easi...eir_theyre.htm
Is it OK to show this stuff?
I've cobbled a few pieces together from the junk yard into a dual exhaust to make it driveable until I can get it done properly. Now that winter has set in I can't work on it until warmer weather comes back.
Have you checked Rockauto?
vince1 is offline   Reply With Quote
1965, 283, exhaust, exhaust system, long bed
