Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Vendor Reviews
Old 08-22-2019, 05:08 PM   #1
tbone67
**Blueprint Stands Behind Their Engines***
I bought a Blueprint 383 crate motor for my 1972 Blazer and it hydro locked after 150 miles over a 4 month period. They told me right away that because I installed it myself, they wouldn't cover labor. Ok, either way I had a Chevrolet dealership do the repair work because I didn't know exactly what I was in for. They started taking apart the motor and discovered that the intake manifold bolts were loose (motor came with the intake) and the heads were old pieces of junk. Major signs of electrolysis and multiple pins installed from crack repairs. This is a high 405 hp engine and you shouldn't be using junk heads waiting to fail. Blueprint kept insisting I overheated the motor and that's why the heads warped. This motor never overheated!!! The junk heads were the cause of this whole thing. The enormous amount of electrolysis on the head and the loose intake manifold bolts with heat and pressure from normal use caused the intake gasket to leak and let coolant flow. This was driven for 150 miles over a 4 month period. Ridiculous!! Keep in mind I bought this motor because it comes with "NEW CAST IRON VORTEC HEADS"!!!!!!!! Buyer beware…it doesn't! Also the cross hatching is gone in the cylinders and they are shining. How can that be gone in 150 miles. I question if it was ever even honed as they say. I'm surprised this thing held together during the so-called dyno run. Blueprint gave me the whole rundown on how they air check everything and torque everything, maybe it held together from them but fell apart for me. I bought this motor because I wanted a reputable company to stand behind their product with a warranty. I didn't want to have some local shop or shade-tree mechanic build one and then have he said/she said issues if a problem would arise. The joke is on me! I understand they can't pay out every warranty claim that comes through the door but I am getting the shaft here. Absolutely depressing and now I am out $2k for labor repairs (not including the tow bill). The Chevrolet dealership agrees with me and also is disappointed with Blueprint not standing behind their product. I watch all these automotive shows with Blueprint sponsorship and advertisements, I was excited and proud to buy my Blueprint motor...not anymore.
Last edited by tbone67; 08-28-2019 at 06:46 PM. Reason: Worked out a suitable outcome with Blueprint
tbone67 is offline   Reply With Quote
Old 08-22-2019, 05:33 PM   #2
mgkgmc
mgkgmc's Avatar
Re: **do not buy blueprint engines***
Looks like they are rated with the Better Business Bureau you could leave a review on there.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 08-22-2019, 06:51 PM   #3
tbone67
I will be and thanks for the information. Much appreciated!!
Old 08-22-2019, 05:38 PM   #4
bigdog55
bigdog55's Avatar
I'm needing a new motor myself. I considered getting one of theirs, Now I have second thoughts.
Brian
bigdog55 is offline   Reply With Quote
Old 08-22-2019, 07:10 PM   #5
jimijam00
You knew the warranty terms before purchase, right?
jimijam00 is offline   Reply With Quote
Old 08-22-2019, 07:28 PM   #6
tbone67
No, but will admit I didn’t read through them thoroughly either. I just saw the 30 year/50,000 mile warranty. Regardless, they are using parts that shouldn’t be used. Those heads should have been scrapped to begin with. I understand that you can rebuild things and reuse them but not on a high profile build like this. Blueprint is in business to give us something that we need and make a profit while doing so. Unfortunately sometimes they use equipment they shouldn’t. I’m sure most times people install their motors and rarely drive or even start them and by the time there is an issue years have passed. Not this time.
Old 08-22-2019, 07:39 PM   #7
tdangle
tdangle's Avatar
That is really too bad a company would put together an engine using bad used parts. I can see a used block, but they do state new heads. I also thought they dyno ran all of their engines??
This just reinforced my decision to go with new from GM.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 08-22-2019, 07:46 PM   #8
BigBird05
With GM crate engines being affordable, that is the best way to go.
BigBird05 is offline   Reply With Quote
Old 08-22-2019, 07:50 PM   #9
tbone67
The vendor I purchased the engine stated new heads. It also said computer aligned honing job. There should be signs of the honing job present after 150 miles. Blueprint disagree with me. I’ve spoken with multiple mechanics and said there should be definite visible signs of the crosshatching. Blueprint said they don’t use new heads on this setup. I learned this after the fact. Point being the heads used should have been scrapped and not used. If it was me, I would go with the gm crate motor.
Old 08-22-2019, 07:51 PM   #10
tbone67
I do have the printout of the dyno run, means nothing to me.
Old 08-22-2019, 08:22 PM   #11
Mbeef61
Mbeef61's Avatar
If the vendor said new heads and blueprint said they are not I would be going after the vendor for false advertisement/fraud
Mbeef61 is offline   Reply With Quote
Old 08-22-2019, 09:16 PM   #12
tbone67
Next step. But just making people be aware of what kind of work Blueprint is capable of.
Old 08-26-2019, 10:14 AM   #13
kacy
kacy's Avatar
Then why arent you blasting the vendor like you are blueprint? Maybe the vendor thought they could pass off some other companies engine as a BPE and no one would know.
post the link to the vendor and engine you bought that specifically says its a BPE.
79 Corvette- 406/7004r Holley EFI
87 V10- 5.7L, Vortec heads, E110026, 410s 35s, 700r4
kacy is offline   Reply With Quote
Old 08-23-2019, 01:14 AM   #14
54Caddy
GM Addicted
54Caddy's Avatar
Dang not good to see at all. I installed a blueprint 383 roller in a customers 67 truck recently he has about 1,500 miles easy in the past four months have no issues with it. Also another in a 73 truck and no issues. These are both with their new aluminum heads and were both purchased as long blocks.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 08-23-2019, 01:34 AM   #15
siggyfreud
siggyfreud's Avatar
Did you buy direct (if that's possible) or get it through a reseller? Perhaps the reseller bamboozled you?
siggyfreud is offline   Reply With Quote
Old 08-23-2019, 07:35 AM   #16
68Gold/white
I am wondering same..........
68Gold/white is offline   Reply With Quote
Old 08-23-2019, 08:16 AM   #17
67C10Step
67C10Step's Avatar
Anyone can sell you something. The true reputation of a company is made in how they handle when something goes wrong.
If the heads were advertised as new and you have evidence to the contrary that is enough of a deal breaker for me right there. All the rest is just more evidence of a poor job. A dyno sheet to me is worthless unless I see the engine on the dyno in video or with my own two eyes. Too easy to fake a dyno sheet, not that I am accusing Blueprint of that.
I hope you get some satisfaction on this and please keep the group posted.
67C10Step is offline   Reply With Quote
Old 08-23-2019, 06:25 AM   #18
150 miles isn't even a break-in period. Sponsoring TV shows and other forms of "paying" to get your name out there is just that, "Buying a reputation" not earning one. It sounds like using "Blueprint" in their name is a decoy. A precision built engine is not necessarily blueprinted. They are misusing the term right there. Big means nothing these days. More than anything it means they cut a finance deal for a big line of credit with a bank.
You are better off dealing with that guy in your area who's name comes up when talking engine building. I use Mark Pickett, ever hear of him? You know, the guy who lives back off of Old West Falls Rd in Back Acres Estates with the machine shop in his attached garage. The guy who does all the machine work and engine building for the repair shops in the area and those hot rodders and racers who are in the know.
The engine in my '72 K2500 "I" rebuilt in '91 and is in it's second truck. I disassembled, used a local machine shop for the machine work, supplying bearings to match the resulting specs, and I went ahead and had them assemble the heads. I don't call myself a mechanic or an engine builder, but I assembled the block, then heads, with great care and attention to every detail checking myself along the way. This was the 4th or 5th engine build for me. I know what's in there and I would be no better off with a GM crate engine. The proof is in the pudding.
Old 08-23-2019, 12:18 PM   #19
jeffahart
jeffahart's Avatar
I would keep fighting with Boofprint. Tell them sayin' ain't doin'. If they did what they claim you wouldn't be talking!
It's funny you mention the name and blueprinting. I have been looking closely at the BP3503CT1. I like the price per pony. But one thing that really bugs me is they use the term "Seasoned Block", and that kind of bothers me. "Seasoned block" is another term that gets tossed around like every used block is a good seasoned block. I don't mind a two bolt main for that power, but the term seasoned bugs me in their context. With today's metal tech, I'm thinking I would rather have a new block then one called seasoned. Probably overheated and stressed. But now I see their seasoned heads! Actually... not funny!
j
White K20
jeffahart is offline   Reply With Quote
Old 08-23-2019, 12:30 PM   #20
weq92f
weq92f's Avatar
Originally Posted by jeffahart View Post
...But now I see their seasoned heads! Actually... not funny!
Not funny! If it's all about profit, why would they use anything but the cheapest blocks and heads they could get their hands on? If we follow the profit trail, imagine the quality of the components they stuff inside those castings...
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 08-23-2019, 01:03 PM   #21
James K
Hate hearing stuff like this.
I bought the BP38313CTC1D and have about 1500 miles on it since May with no issues.
James K is offline   Reply With Quote
Old 08-23-2019, 01:40 PM   #22
jeffahart
jeffahart's Avatar
Don't stress, the odds are, your motor is fine. Plus you have the aluminum H8002K heads, I think. Anyhow, I wouldn't worry too much.
j
White K20
Old 08-23-2019, 01:38 PM   #23
jeffahart
jeffahart's Avatar
-klb
Yeah, and I kind of feel like the more component failures a company has, the tougher they get on warranty replacement because they're losing money on too many warranty calls. They should have tripped over their feet to get him some H8002K heads, along with an apology.
j
White K20
Old 08-23-2019, 09:40 AM   #24
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I've always had good luck using a couple of local machine shops. They have been around a long time and that is a god sign of quality.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 08-23-2019, 09:58 AM   #25
LEEVON
LEEVON's Avatar
Well that sucks. If they sold you an engine with "new" heads that should be enough to dispute the entire transaction.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
