11-12-2007, 08:44 PM | #1 |
78 C-10 how to shorten steering column??
I searched the forum looking for a definitive answer, didn't find one. Have any of you guys shortened the steering column on your truck? I've got the seat all the way back and still have to bend my elbows past 90 degrees to hold the wheel. If I could move the wheel closer to the dash by 3-4 inches, it sure would make it a lot more comfortable. There was a mention of a telescoping Cadillac column but no year model was given for the donor or the truck it was going in. Another post for a '84 said he used a '86 Caprice column. Nothing specific to my '78. Help!!
11-12-2007, 11:15 PM | #2 |
Happy to be here
Re: 78 C-10 how to shorten steering column??
Do you have a tilt? That made a HUGE difference in the comfort on my truck.
11-12-2007, 11:28 PM | #3 |
It is a tilt column and even has a smaller aftermarket wheel but it needs to be closer to the dash.
11-13-2007, 11:18 AM | #4 |
Robert Olson Transport
i know how you feel im 6' like 270 lbs and it seems tight for me too i have no clue but eagerly wait for an definitive answer myself
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
11-13-2007, 01:02 PM | #5 |
There is a write up on the 67-72 boards about collapsing the steering column a couple of inches -- but i dont know if it will work on a later model.
You would have to find the thread to get all the details - but basically , you unbolt the colum, take the center section out under the hood and collapse it - move it forward in the cab and re-attach. This was a safety feature years ago - if you got into a hard enough impact , the column would collapse and absorb some of the energy -- so pre-collapsing would negate that feature - so dont drive into any brick walls if it works |
11-13-2007, 01:36 PM | #6 |
ive never checked to verify it , but ive heard the columns from full size vans are shorter then trucks
11-13-2007, 02:10 PM | #7 |
Dark Heart Motorsports
next time I go out to LKQ I will measure some for yall that are close to the same kind of build (i.e. chevy vans, trucks, cars), and tell you what their lengths are... Its on my to-do list now, so when I go out there next monday I will return with results
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
11-13-2007, 02:26 PM | #8 |
Thanks, I read the write-up in the 67-72 boards. It is very informative but not specific to my '78 C-10. It's a different beast and I'm hoping someone else has shortened their column or found a shorter replacement that's close to a drop-in.
11-13-2007, 08:06 PM | #9 |
I have an 85 ck and I have the same problem. They built the seat too close to the dash for me>. 6 ft and 300+ lbs. But im not giving up my truck!!
01-28-2008, 09:57 AM | #10 |
Is there any update on this? I'm wedged in right now.
01-28-2008, 02:32 PM | #11 |
Most 77, 78, and 79 Olds 98's (caddy's and big buicks prolly did too) had a tilt and telescoping columns. I have owned two and both had them. I currently have one that is still in the car if interested. It has the key and cruise switch. Let me know
87 black silverado swb, tbi 350, 700r4, 3.40 gears. 2.5 drop spindles , 2 inches off stock coils, flip kit out back. cragers with radial ta's... ongoing piddle project! 1970 Olds rallye 350, street strip 403/350 3.73 posi. Looks stock/runnin 12's! 86 K5- SOLD! |
01-29-2008, 01:26 AM | #12 |
I'm interested. Are you fairly certain that the column will work? Bolt in or much modification necessary? I was considering moving the mounting bracket about 2 inches up the tilt column that I have.
01-29-2008, 02:12 AM | #13 |
In the Forgotten far North.
Have you thought about changing out the seats? My '90 burban had the factory bench seat in it with factory whel and no tilt. Steering wheel was in my belly all the time as well even with the seat all the way back(I'm 5'10" & 320#) put in a Grant wheel w/quick disconnect, still in my belly but not as bad. then I found a set of custom bucket seats with center console/jump seat, got them installed and now I have about a 3 inch gap between wheel and belly. Little more head room too and the seat isn't even back all the way either
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
02-05-2008, 01:19 AM | #14 |
what about aftermarket columns? has anybody used them? My 73 dosnt have tilt and Im hating it.
1973 C10 "Chain Reaction" Street Trucks cover Feb 2012 2013 Silverado 1964 Cadillac |
02-26-2015, 05:10 PM | #15 |
man I don't like abandoned threads especially when they were spot on for what I was interested in doing, so resurecting rather than starting a new one
02-26-2015, 06:41 PM | #16 |
Me to. I will be following...
03-02-2015, 03:29 AM | #17 |
I'm interested in the answer too. I'm working on a crew cab so I may just move the seats back if I can't find the answer.
01-23-2020, 05:43 AM | #18 |
Hello from Germany,
i´m interested in this too and even though this thread is very old i´m curious if someone found a solution. I found that squarebody syndicate sells a new column that is shortened 2" towards the dash. Now i need one that is shortened in the enginebay to fit a new shaft for a rack and pinion steering setup! Are there any measurements i can work with?
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ´81 GMC C 10, Spanish Red |
01-23-2020, 07:20 AM | #19 |
I wonder if the Camaro columns are any shorter. I have just been suffering through it for 40+ years.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-23-2020, 06:36 PM | #20 |
There's always this but it is pricey. I have no experience with it, just came across it a while back.
https://squarebodysyndicate.com/inde...egory=11122134 |
01-24-2020, 07:49 AM | #21 | |
01-24-2020, 12:01 PM | #22 | |
When you drive the shaft in 2.5 inches. You have to modify a few things. First measure the column mount bolt centers. This is how much you can easily shorten. If you want custom the welder will be involved. The amount you shorten you need to move your park neutral safety switch on the front of the column up to match. You will need to cut slots into the outer column, and the inner column to match. Then get a piece of exhaust pipe to cover the old hole or water can get in. I welded mine on, but you dont really have too. My column worked fine the way I did it, but my friend had to trim some plastic to work it. Also the PRND21 slider may not work. Mine didnt work before so no change there. Then reassemble the unit. |
