02-07-2020, 03:29 PM | #1 |
Radiator/Shroud Mount Questions
OK; just bought myself an '85 C10 short bed; it's a bit rough, but sure worth bringing it back. Now, among the things the previous owner did was to pull the radiator, and install an aluminum one with dual electric fans. Now, some folks will think I'm crazy, but I want to go back to a regular fan, clutch, radiator and shroud. The only piece I have is the shroud itself; all the rest had been tossed. I've figured out some of this, but have two questions: 1) on an '85, what actually holds the radiator in place - brackets or a top plate; and, 2) what does the shroud actually attach to, top and bottom?
Thanks for any help... |
02-11-2020, 01:49 PM | #2 |
Re: Radiator/Shroud Mount Questions
This diagram from LMC should help a lot. Notice that there are two types of upper brackets (#10 and #11), for different height radiators. The #9 cushions are used between upper brackets and radiator. They also sit on the frame crossmember to support the radiator.
https://www.lmctruck.com/1973-87-che...tor-components
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-15-2020, 12:47 PM | #3 |
Side note you will need 4 studs with nuts @ pump pulley (or bolts & nuts) clutch & clutch fan 4 bolts & nuts for the fan to clutch. There is many types lengths clutches shafts and spacers. You need the fan blades to be between 1/4 to 1/2 way in the shroud work the best.
As said mounts for the rad here more info..http://bowtieguy.proboards.com/threa...nting-brackets
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
