03-13-2020, 10:54 AM | #1 |
1972 K10 gear ratios
The tag on my front differential is 3.07 rear is 3.08 posi
My question is they always different on front vs rear by small amount? |
03-13-2020, 11:51 AM | #2 |
Equal opportunity joke ofender
Re: 1972 K10 gear ratios
yep
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
03-13-2020, 12:07 PM | #3 |
Proprietor of Dale's Corner
I believe up to 10% is allowable.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
03-13-2020, 12:25 PM | #4 |
Not always, but frequently. The different sizes of the differentials makes it impossible for them to match perfectly in some ratios.
03-18-2020, 04:47 AM | #5 |
Collector of Projects
03-21-2020, 10:00 AM | #6 |
ManNamedJed is on the right track. The ratios need to be close and some of that is dictated by what gear ratios are available in a given axle design. And some of that is based on general sizes of the gears themselves, carrier breaks, etc.
It is not a design parameter to have different gear ratio in front vs. rear. 3.73 is a good example of that. In the case of the Dana 44 front where 4.09 is a common ratio, and a Dana 60 where 4.10 is the common gear. You see 3.54 in Danas and 3.55 in GM's. All of these are close enough as running 5 psi pressure difference in tires front/rear. Guys who run Dana 44 front and 9" Ford rear with the 3.54 front/3.50 rear.
