03-28-2020, 12:15 PM | #1 |
Finicky Fuel Fill
Mine is a 1975 C10.
It has been a pain in the butt to fill the tank since I bought it. At least here in California with the Fuel Pumps (SMOG Crap) with the recovery hose. We were in Arizona for a while and no problem with filling. Any of you guys have a repair or solution? I would rather not relocate the Filler Tube but if needed that may be an option. Thanks in advance Steve
Steve 1975 Chevy C10 Short Bed Fleetside Last edited by prairieschooner; 03-28-2020 at 12:57 PM. |
03-29-2020, 08:54 AM | #2 |
Just here to tinker
Re: Finicky Fuel Fill
I always just had to hold the nozzle sideways when filling my '78. That helped keep it from kicking off.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
03-29-2020, 10:03 AM | #3 |
There are several different filler necks.
I found a 86 Chevy with a 6.2 diesel. The filler neck was opened (with no emission crap) also the hose was bigger. I used the tank and filler neck on that truck. It made the fill-up easy. You may want to look for this set-up if your emission will allow it. Here is a link below , I found for the filler neck. I don't know if you could adapt this to your current tank , Because the inlet tube on the tank is probably smaller. Hope this helps. Link:https://www.ecklers.com/1984-1987-ch...All%20Products .
03-29-2020, 10:38 AM | #4 |
Thanks guys! I have been trying to keep the Pump Nozzle slanted and that helps a little. Still doesn't fill like the earlier type, I could actually set it on full and walk away when in Arizona.
I'll have to contact Eckler's and find out about that Filler Neck. Bummer is that I ordered 2 new tanks before we started our winter travels to get out of the snow and surely can't return them now. .[/QUOTE]
Steve 1975 Chevy C10 Short Bed Fleetside |
