04-18-2020, 11:32 AM | #1 |
C10 CLUB Y QUE!
vortec motor
trying to find out if any one still kept the serpentine pulleys on this 96 thru 99 engines. I am asking since the water pump has extra outlets that i wont need and wondering if you are able to block those off or even use a different water pump?
04-18-2020, 08:46 PM | #2 |
Re: vortec motor
i have 88-95 full serp setup ( aluminum brackets ) no bolt on problems minus remake / modify the support brace rod to intake off the tensioner position .
i used a 88-95 water pump and then top 3/4" pipe water port got a hose to the intake just below the t-stat on my edelbrock intake . just like a bbc has a bypass hose . reason for bypass hose is in the 2nd pic . some say you need to tap the hole in the water pump deep and put in a flush mount plug and have it sit just below the surface . but only if your black dosn't have the flat spot on the area for the gasket to seal it off . other than that she is running and working just fine after 6k+ miles now .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-19-2020, 12:16 AM | #3 | |
C10 CLUB Y QUE!
Re: vortec motor
04-19-2020, 11:07 AM | #4 |
Re: vortec motor
NOPE thats std spin pump for v-belt and has extra lower boss for p/s bracket to bolt on .
if serp belt you need the reverse spin for serp belt years . and you need to have a bypass hose or the cooling system can girggle and bubble and make a coolant smell when running each time the t-stat opens . i had this problem until i did the bypass hose .
04-19-2020, 08:43 PM | #5 |
Re: vortec motor
What he ^ said.
04-20-2020, 12:05 PM | #6 |
C10 CLUB Y QUE!
Re: vortec motor
thanks guys.. Love this Forum!
