04-03-2020, 10:24 PM | #1 |
Alarm Wiring - Light Flash Output
I'm wiring an Avital 3100 alarm and power door lock kit from A1 Electric on my 1979 K5. I have almost everything hooked up (door locks, siren) except the light flash output. I want the parking lights to flash when I arm and disarm the system.
The alarm module has a jumper and can be configured to output either a (+)12V, or a (-)200mA output suitable for driving factory parking light relays. Here's a link to the alarm install manual: https://www.directeddealers.com/manu...12%20print.pdf for reference. Any suggestions on how to connect the "Light Flash Output" to flash my park lights? |
04-04-2020, 10:01 AM | #2 |
Moderator
Re: Alarm Wiring - Light Flash Output
"In the (+) position, the on-board relay is enabled and the unit will output (+)12V on the H1/2 WHITE wire."
If I read that correctly the alarm unit has an internal relay to drive the parking lamps when you select the + jumper position. Tie this White wire to the parking lamps power wire. Don't use Scotchloks or butt splices. They mangle vehicle wiring harness.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-04-2020 at 10:48 AM. |
04-04-2020, 01:25 PM | #3 |
Thanks Hatzie. Yes it has an onboard relay. Am I able to make that connection under the dash? I'm hoping to avoid another wire out the firewall. I also have a new AAW harness, so like you said want to avoid any splices.
The headlight switch has a parking light and a taillight output. I believe they are connected on the switch. Could I tie in at the switch?: |
04-04-2020, 03:24 PM | #4 |
Moderator
You can connect to the switch.
The GM wiring diagrams show the layout of the original switch plug so that may help. If this is one of those "universal" wiring harnesses you essentially have a completely custom wiring setup. I'm not sure how much help I can give you. You'll need to hang onto the documentation from AAW. Hopefully they have a decent wiring diagram.
And please let us know if and how your repairs were successful. |
04-04-2020, 04:31 PM | #5 |
I have the AAW 1973-82 Classic Update Kit so for the most part its nearly identical to my factory harness. Here's the instructions with that kit:
https://www.americanautowire.com/pub...20IN%200.0.pdf On sheet 3, the headlight switch wires are labeled, so I'll tie into the brown "Park Lamp Feed Out" on that harness. Thanks |
04-06-2020, 11:48 AM | #6 |
Hi Hatzie. It worked great. Thanks for your help.
Front and rear lights flash with the alarm by connecting to one of the brown wires at the headlight switch. The switch itself connects both brown wires so connecting to one flashes both the front and rear lights. Video posted on my IG account: @square_k5 https://www.instagram.com/p/B-nfHWVJ..._web_copy_link Last edited by pid; 04-06-2020 at 12:07 PM. |
04-06-2020, 08:56 PM | #7 |
Wow is that the relay making that noise when they flash.
Nice looking truck
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
04-06-2020, 09:00 PM | #8 |
No, the noise in the background is the door lock actuators. The actuators have a good strong punch to them. I got the door lock and alarm kit from A1 Electric. |
04-07-2020, 01:38 PM | #9 |
I bought Door lock actuators from them for my truck about 15 years ago and they still work great. They are loud as hell though. I wish I had done something with an alarm too.
04-08-2020, 12:02 AM | #10 |
Yeah, the actuators sure pack a punch.
The alarm was much easier to install than I expected. I only hooked up the door locks, siren and light flash output, but adding the ignition kill would have been easy too. I just put a new AAW wiring harness in so wanted to limit modifying it as much as possible. The main reason I installed the alarm was for the key fobs with my power locks. |
