01-16-2021, 03:20 PM | #1 |
Active Member
top altinator mounting hole not threaded
New remanufactured Delco, no threads in top hole, factory defect? Just use bolt, washer , nut? or return it?
01-16-2021, 04:58 PM | #2 |
Re: top altinator mounting hole not threaded
It is a defect. You should return it if it is not too inconveniant. I have used a bolt & nut & washers many times when the threads were stripped.
George |
01-16-2021, 07:00 PM | #3 |
Tap it?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
01-16-2021, 09:57 PM | #4 |
what's the easy way? tap, bolt & nut or return it?
01-16-2021, 10:11 PM | #5 |
The easiest is put a nut and bolt in it.
The right way is to return it and require the supplier to provide the correct part. Tapping it may or may not a work depending on the size of the hole that isn't tapped. If it is too large then the next size up bolt is likely going to be too big for the bracket. We Hot Rodders are too quick to modify a new part that is incorrect in order to get things done. But the reality is that after 60 plus years manufacturers still don't know how to make a correct alternator bracket for a SBC since no one ever returns them because it doesn't fit. So they keep selling stuff that doesn't fit correctly. As I am guilty of this too I will now get off my soapbox.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-16-2021, 10:20 PM | #6 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-17-2021, 10:14 AM | #7 |
Active Member
Will return to NAPA, I guess delco doesn't mean usa made anymore? Maybe someday again?
01-17-2021, 07:31 PM | #8 |
Old member
I would drill it out and use it. Hopefully it would charge right. Then if it didn't I would return it.
I always put a long enough bolt in it anyway to put a lock nut on it. I don't trust the threads.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-18-2021, 08:28 AM | #9 |
It may not be a defect. There are some non-automotive applications of the 10SI alternator that use a bolt with a nut or threaded bracket because the alternator is fixed and something else is used to tension the belt. You could thread it, use a nut on the back, or helicoil it.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
01-18-2021, 08:50 AM | #10 |
Been that way a loooong time! Mexico or China (and lots of other cheap labor locations) is where everything is made these days. I am a die hard buy American guy and it gets more difficult every day. Some manufacturing was coming back but that is about to end!
01-18-2021, 12:38 PM | #11 |
Nut,washer, bolt. Done.
Unless you need chalkmark correct. I much rather the nut and bolt, over the threads in the case And a steel bolt. |
01-18-2021, 01:25 PM | #12 |
You could Heli-Coil it.
Take Care Troy |
01-18-2021, 01:59 PM | #13 |
I'll add my opinion that it may not be defective. The upgraded alt I put in did not have threads. Also, agree with Andy, more secure to use a bolt and a lock nut. Much easier than drilling and tapping. Doesn't look bad either.
